Pulling ac 210
Navyrunfm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Navyrunfm Quote  Post ReplyReply Direct Link To This Post Topic: Pulling ac 210
    Posted: 25 Aug 2019 at 1:57pm
Anyone have opinion on what gear to pull my 210 in at local fair farm pulls??
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2019 at 3:54pm
Will greatly depend upon how heavy the tractor is and how much HP it has. Low gear will work for sure. Second gear will probably work. Third gear and up and you may have power issues.  Track conditions/soil type/moisture levels all play a part in traction and engine power requirements.
mike a View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike a Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2019 at 2:06pm
speed limit pulls?
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2019 at 3:39pm
A practice pull of some kind helps, hook to a bulldozer with the chain under the blade will give you a good feel for pulling, but anything big Can give you some idea of where you are at, try to do it on a hard packed dirt drive or something. Should be able to spin out in 2nd otherwise adjust accordingly.
