Pulled the trigger……………
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Topic: Pulled the trigger……………
    Posted: Yesterday at 12:27pm
And acquired a 2012 Ford Expedition. 2wd, Limited. 143,000 miles, original owner got nearly every ‘upgrade’ option available at the time. Will be going into a shop, to deal with the ‘Cam Phaser’ issue that plaques the 5.4L. The shop has given us the option of the ‘stock repair kit’ or, for an additional $1,000.00 the ‘delete kit’. Will more than likely opt for the stock repair.
Darwin W. Kurtz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darwin W. Kurtz Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 12:33pm
how is the stock repair kit better than the original - if the phasers went bad before, won't it happen again. A local mechanic told me to steer clear of anything Ford for the reason of the phasers going bad
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 3:26pm
The the stock, would be Motorcraft. The delete would aftermarket. The aftermarket kit basically eliminates the VVT, and there are some sensors that are also eliminated, and a couple hours of re-configuration of the onboard computer. The stock option is basically replace with factory.
My mechanic says the worst thing people do with those VVT engines is extending oil changes. Sensors get dirty, cam phaser gets sluggish. He says to ignore the computer telling ‘oil change needed’, those generally will signal at 8,000-9,000 miles, that’s way too long for those engines, 3,500 mi, with full synthetic oil is the best, and cheapest thing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darwin W. Kurtz Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 3:37pm
Thank you Lars,   That explains alot - so if you change the oil regularly at a lower interval say 3500 miles. you have very little trouble?
So if a person is buying a used vehicle, one needs to check how often they changed the oil to avoid having to fix the problem
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 7:40pm
Lars... your Mechanic is 100% on base... The variable cam timings is controlled by oil pressure thru a couple of small orifices.. Works GREAT if the oil is clean... Causes problmes and WEAR when oil plugs the ports... Some have trouble at 100K miles, some dont have problems at over  200K..... Go with the MotoCraft parts and change oil regularly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 7:42pm
GOOGLE search pretty well spells it out.........
A 5.4L Ford engine with Variable Cam Timing (VCT) can last well over 200,000 miles with proper maintenance, but its longevity is heavily dependent on addressing known issues like cam phaser problems and performing timely oil changes. While some owners have had issues, many report their engines are reliable when cared for, with some achieving 250,000 to 300,000 miles or more.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darwin W. Kurtz Quote  Post ReplyReply Direct Link To This Post Posted: 22 hours 44 minutes ago at 9:49pm
What should the oil pressure be?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 22 hours 30 minutes ago at 10:03pm
hot idle should be 25 psi... may run up to 60 psi at full throttle... Problelm is dirty oil can plug the ORIFICES and main galley might be OK, but no oil getting to the VCT units... they wear out, then cam timing is BAD.
There are also aftermarket pumps (Melling??) that are often used during rebuilds to up the VOLUME to maintain good pressure ..... The SENSOR for oil is an on- off switch that closes at 8 psi, so you really cant use the Factory Gauge ( it is just a yes- no , if you have over 8 psi).
Edited by steve(ill) - 22 hours 27 minutes ago at 10:06pm
