Pull Type Disc ID
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Topic: Pull Type Disc ID
    Posted: 26 Oct 2016 at 4:59pm
I just obligated to buy this 7' drag disk. It's the kind that you straighten the gangs for road transport. It looks like an Allis, but does anyone know for sure? And if so, what model?
Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2016 at 5:14pm
I have the same disc if it's 6 foot. I thought it was called a #10 ? Those frames that the weights are on are perfect for setting 2 cement blocks in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2016 at 5:28pm
Thanks Charlie!
cement blocks...like cinder blocks? If so...why just 2?
Edited by CrestonM - 26 Oct 2016 at 5:29pm
Auntwayne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2016 at 9:00pm
   You need to figure out what the tractor weights belong to.  Might be able to make a few bucks ? Free disc ?
Dad always said," If you have one boy, you have a man. If you have two boys, you have two boys". "ALLIS EXPRESS"
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2016 at 9:20pm
The weights aren't included.
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2016 at 9:26pm
Now that it is ID take the pictures down you have some green parts there and you don't want it PINK some morning.
The solid rounds with the T on the back are 100 lb weights from JD 36  pull harvester.Counter weight for the header lift,before hydraulics and a 20 foot head has some weight to it.  It would cut with the JD95 or a Gleaner C. But to make green haters  happy JD did not design it they bought rights from Caterpillar in the 30's. Was a Holt design from the teens.JD did sell them until in the 50's when they had the 95 to replace it.
Disc looks to be in good shape not bent and welded.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2016 at 9:58pm
Learn something everyday! Good thing the weights aren't mine lol
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2016 at 11:37pm
that type of hitch same as one i have MM or oliver
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2016 at 4:16am
Thanks Charlie!
 On mine, 2 fit nice on each gang. That is 8 blocks total.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2016 at 6:55am
It's an Allis disk. I have a manual for one at home. I'd have to dig it out and see what the model is.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2016 at 7:55am
Thanks guys! Looks like it will be a great match for my WC!
CALEBnOK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CALEBnOK Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2016 at 9:30am
The weights are off my #34 holt combine. Wheel weights are off a moline we had
RMD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RMD Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2016 at 9:45am
Doesn't look like the 6 ft. tandem AC disk that we had which I thought was a No. 10. Hitch and adjusting mechanism are quite different.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2016 at 10:49am
The mind is going as fast as the body is. They only weigh  50 lbs on the Holt36 and think the 34 is the same. Just feel like 100 now with my  old body. I'm sure Creston dose not have this problem.
I can supply some nice limestone rocks to weight your new disc. You roll into my tractor bucket and I will deposit in your truck(carefully) for free.
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2016 at 11:42am
It's not a #10.   Rear hitch and angle adjustment is different.  I'll have to look in one of my old books to see if I can find a picture and correct model number.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2016 at 10:15am
According to my book, it's a #9 tandem disc.  I have three in the barn, six, seven, and eight foot.  All for sale.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CALEBnOK Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2016 at 5:37pm
I put it in road position and the rear gang is 8ft 6" wide.
