PTO yoke pin
Allisrod View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allisrod Quote  Post ReplyReply Direct Link To This Post Topic: PTO yoke pin
    Posted: 19 Aug 2023 at 8:06pm
I just bought a 5 foot pole behind Allis Chalmers rotary mower. I need to put in a new PTO yoke pin. Can somebody please tell me the right size and correct one to purchase? Thank you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2023 at 8:29pm
Welcome to forum. Have any pictures of what you’re looking for
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2023 at 8:50pm
Replaced the pin in a AC sickle mower with one from Sandy Lake IMP. Pretty sure they are all the same but they can tell you for sure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2023 at 4:45am
I think there are only 3 types. If you have a TSC or somilar nearby, buy one of each, and compare to original...  Or, take the original out, and take to store, to compare on sight...LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2023 at 8:38am
almost all of them are 1/2 inch "STANDARD" size... there are a couple odd balls, but MOST use this pin.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2023 at 1:11pm
That's like the one on my Woods. It keeps breaking off at the small dia. Got tired of that so use a screwdriver to poke it....not handy.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2023 at 9:19pm
If it is breaking off, you have a problem with telescoping part of PTO. Too long or not telescoping easy enough.                      MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2023 at 12:22pm
I need to double check but I'm sure the telescoping slide has more than enough travel and I keep it greased. I shortened the drawbar a few years ago to get the geometry correct on the two front u-joints in a turn. Took a lot of hammering out of the turns. Maybe that had something to do with it. I should replace the pin and see how long it lasts.
This page was generated in 0.039 seconds.
