Pto shaft and other parts
shieldslx View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shieldslx Quote  Post ReplyReply Direct Link To This Post Topic: Pto shaft and other parts
    Posted: 05 May 2011 at 8:34am
Hey guys, I'm a die hard allis enthusiast with a machine shop . I'm currently cutting a pto shaft for my dads 220, any orders for any parts would be much appriciated. Have a great day guys
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2011 at 9:09am
Just out of curiosity, what part of kentucky are you in?  I'm in Midway, and if you're near, PM me your information for your machine shop and I'll save it for any time I need machining work done.  I don't know a good general machine shop near by right now I can confidently send stuff to and get it done in a timely manner, and it never hurts to have one of those in your contacts list, especially working on machinery and old cars.  Might have a manure spreader that needs a stripped spline pinion shaft on the gear box repaired this summer.
Hurst
1979 Allis Chalmers 7000
5800 Hours
Post Options Post Options   Thanks (0) Thanks(0)   Quote shieldslx Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2011 at 12:58pm
My shop is shields design and manufacturing, my name is Benjamin shields, 8592271340 the shop is in burgin but I'm in Lexington so pick up and delivery would not be a problem. Thanks for the reply, I'm just starting out and can use all the work I can get.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2011 at 2:11pm
Benjamin - if you are producing PTO shafts for 220's/210's that's a good thing.  I know the last time I talked to Niel Evans at Northside Salvage (Red Bud, IL), his advice to me if I ever got one of those tractors was to not use it for any PTO work as the shafts are nearly impossible to find used if you break one.
Anybody - does the D21 use the same PTO shaft or is it different?
Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2011 at 6:44pm
I've got your number in my phone.  If you can grind flywheels, I may have one to do when I get home from school.  If you can do it, how much does that run these days for a stepped flywheel?  It's been a while since I've redone a clutch and had a flywheel resurfaced.
5800 Hours
Post Options Post Options   Thanks (0) Thanks(0)   Quote shieldslx Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2011 at 8:44pm
If you could send me a picture and some general dimensions for it I could give you a better estimate, thanks.
