PTO on a dozer why |
OldSchoolRecovery
Joined: 06 Nov 2015 Location: Eagle River, WI Points: 301 |
Topic: PTO on a dozer whyPosted: 16 Nov 2015 at 10:38pm |
Ok, dont hammer me too bad, but why?
Unless for agriculter, Im not sure what use it would be. I do have farm tractors with pto rototiller, flail mower and manure spreader. Some examples would be nice. My new H3 has a pto if you havent guessed allready.. cb1
OldSchoolRecovery
Posted: 16 Nov 2015 at 10:40pm |
JC-WI
Joined: 11 Sep 2009 Location: wisconsin Points: 34624 |
Posted: 16 Nov 2015 at 11:35pm |
With a pto, you have a the ability for many other attachments. besides running an elevator or buck saw or a water pump or a hydraulic pump or mower... or even attach a logger boom behind it and winch in logs and lift them... etc.
Calvin Schmidt
Joined: 11 Sep 2009 Location: Ontario Can. Points: 4583 |
Posted: 17 Nov 2015 at 5:12am |
I've used the PTO on my H-3 to run a belt conveyor.
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55282 |
Posted: 17 Nov 2015 at 5:47am |
My grandfather's D2 cat had a belt pulley, on the back, we used it on the farm, to grind feed with...
When I ordered my struck MH5000, I made sure to get 3 point and a PTO, makes it a pretty good stationary power unit, much more versatile...
Larry(OH)
Joined: 11 Sep 2009 Location: Shreve Ohio Points: 1580 |
Posted: 17 Nov 2015 at 8:32am |
baling in the hill country :)
'40 WC puller, '65 770 Ollie
*ALLIS EXPRESS contact* I can explain it to you, BUT I cannot understand it for you!! |
Ages Cat
Joined: 12 Sep 2009 Location: Hutchinson, MN Points: 700 |
Posted: 17 Nov 2015 at 12:58pm |
My HD-5 has a belt pulley. We run the sawmill with it in Lesueur. Our HD-3 has PTO and 3 point hitch. Why not? You never know when you will need it.
Curt Anderson
HD3, HD5B, HD6AG,HD6B dozer, I-400,615, 616,620,720,ACP25 lift truck, 1956 D Grader, AC 540 loader, AC #84 plow, Simplicity tractors, Agco MT225, Agco 2025, |
Joined: 11 Sep 2009 Location: illinois Points: 90822 |
Posted: 17 Nov 2015 at 6:20pm |
even 200- 300 HP tractors were ordered with winches (PTO) from the factory.. Military had a lot of them.
Randaleky
Joined: 17 Aug 2011 Location: belfry, ky. Points: 427 |
Posted: 17 Nov 2015 at 7:39pm |
I used the one on my hd4 for a post hole drill.
Dave in il
Joined: 22 Sep 2009 Location: Manville Il Points: 1748 |
Posted: 18 Nov 2015 at 8:53am |
An HD-3 with a 3pt and pto that sounds perfect for mowing multiflora rose.
AGCO My Allis Gleaner Company
Larry(OH)
Posted: 18 Nov 2015 at 10:42am |
could have also pulled a combine on the hills out west
cpg
Posted: 18 Nov 2015 at 11:54am |
Probably part of the reason of finding them on the older crawlers is that like others said they were in the day marketed for farming in certain areas as well.
OldSchoolRecovery
Posted: 18 Nov 2015 at 10:36pm |
Anyone have a picture of 3-point hitch on a H3, thanks,
cb1
fifacome60
Joined: 24 Nov 2015 Location: United Kingdom Points: 1 |
Posted: 24 Nov 2015 at 9:11pm |
I was only lucky to score these goals," Huang said modestly. "I didn't plan to score in a certain fashion and what I was mostly thinking about was setting up goals. But the goals came naturally when I tried." |
combinechris
Joined: 20 Jul 2015 Location: wittenberg,Wi. Points: 424 |
Posted: 24 Nov 2015 at 9:32pm |
My hd-6 has a belt pulley and pto.
