PTO generator
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Topic: PTO generator
    Posted: 07 Nov 2010 at 12:58pm
Here is the generator mounted on my WF. Runs pretty smooth and has full voltage at about 3/4 throttle.
tom (OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tom (OH) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2010 at 1:52pm
What size generator is that?
Tom
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2010 at 1:59pm
It's a 15KW, made by Katolight Corporation in Mankato MN. According to the rule of thumb on HP/KW that is probably as big as the WF can handle.
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2010 at 2:44pm
Nice. Only thing I'd add is a filler over the driveline.  Piece of plywood or sheet metal so you don't slip and step down through a turning driveshaft.  Now, I hope you don't need it this winter.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote tom (OH) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2010 at 3:10pm
What is the gearbox from?
Tom
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2010 at 6:37pm
The gear box is a Federal Seal & Gear Corp. that was on when I bought it. It has a 3.25:1 ratio and at full voltage there are 2 clicks left on the throttle. Aaron, your right about safety, I will add a guard when I pull it off to paint it.
firebrick43 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote firebrick43 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2010 at 9:41pm
Kato makes nice generators.  The big double bearings get packaged into premium sets at work.  2 or 3 MW however in size
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2010 at 11:18am
I bought a brand new 40kw Katolite several years ago but have not run it yet.  Had to build a trailer because I was too CHEAP to buy one.
Nice machines.  I plan to power mine with my AC 180 diesel or J.D. 4050.  I could use the D-17, if the load requirement is light.  I figure 2 h.p./Kw
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2010 at 7:01pm
Nice looking setup, I mounted mine on a small trailer. I finally got my 16kw pto wired for the house, I used the CA to power it on the maiden voyage. It will run the geo-thermal furnace, deep well and water heater, not all at once but I will be babysitting it anyway if the electric goes out. I hope I never have to use it.
Leon B
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2010 at 7:38am
Yep, Kato makes nice genheads.  I've got a Consolodated Diesel Electric generating plant, very, very conservatively rated 35kva, powered by a Hercules JXLD 331ci inline six...  runs at 1200rpm, and man, what a sound!
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2010 at 8:12am
We never sold any but I remember getting literature - don't know from whom - about trailer mounted PTO generators.  We perhaps could have sold some but many used manifold valves to run their milkers with when power was out.
Good Luck!
Bill Long
