PSI Rating on Hydraulic Hose for H3
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Topic: PSI Rating on Hydraulic Hose for H3
    Posted: 04 Mar 2019 at 8:42am
What PSI rating hydraulic hose should you run on an H3? Can't find the info anywhere on it.
Can't fix stupid
NomoreJohnDeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NomoreJohnDeere Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2019 at 9:38am
regular old hydraulic hose gets my vote
HD3
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2019 at 10:13am
But there are different PSI ratings. Hydraulic hoses are not cheap and if I'm gonna spend the money and go through the effort I want it to be right to avoid problems/blow outs as I've had a couple hoses blow in my face before on other equipment.
Edited by AJ - 04 Mar 2019 at 10:19am
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote NomoreJohnDeere Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2019 at 10:32am
get a high rated one
HD3
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2019 at 10:56am
if your using it for a loader/blade cylinder 3000 to 4000 psi hose. is fine.
anything on the a drive pump to a motor 5000 psi hose.
dan
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2019 at 11:21am
I have the pump on the side of the torque tube. Hose to that should be 5000psi?
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2019 at 1:09pm
In the 1970s we use to use a LOT of 3000 psi hoses on the dozers coming out of the Allis Plant.. That is the RATED pressure, so its good for all day long. The BURST pressure is probably double that.
I think most of the tractors at that time were running 2100- 2500 psi operating pressure.
Edited by steve(ill) - 04 Mar 2019 at 1:10pm
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2019 at 4:44pm
Good to know thanks for the info
Can't fix stupid
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2019 at 5:35pm
H3 is a gear pump isn't it? If so it is likely pressure is in the 2000-2200 psi range. A 2 wire braid SAE 100R2 hose would be typical for that application range. The place you are going to get your hoses from should be able to supply that info for their hose and fittings, working psi is marked on a lot of hoses. Like pipe, the bigger the diameter the lower the working pressure. Burst pressure is 4 times working pressure by the SAE standard.
If you want to go first class go with the 4 wire spiral wrapped hose (called CAT hose by some). That is the type usually found on "piston" type pump systems and newer high pressure systems.
Also hardware store pipe fittings don't belong on the pressure side of a hydraulic system and best if not in the suction either. Most are only 150 psi rated.
SAE_hose_types.pdf
sae_hoses.pdf
Edited by Jim.ME - 04 Mar 2019 at 5:37pm
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2019 at 7:46pm
2 wire brade - 2500 max pressure
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2019 at 9:04pm
Found this, I know it a little blurry. Maybe someone has an actual brosure for the crawlers. Am I reading that right that it only has 1500psi hydraulic system?
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2019 at 9:24pm
That looks right for a gear pump of that vintage. 1000, 1250, 1500 were common system pressures in the day for equipment with gear type pumps. You will be fine with two wire braid hydraulic hose.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2019 at 5:36am
On my 7G I opted for what was more common and even as heavier feel more comfortable with heavier hose as takes abrasion or bumps and snags longer, better.
This page was generated in 0.191 seconds.
