psb pump |
tom
Topic: psb pumpPosted: 24 Sep 2010 at 12:30pm |
the lines are good.took the head of the pump this morning hope to have a closer look tonight.
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5204 |
Posted: 24 Sep 2010 at 6:34am |
I have seen psb heads be bad, and have weak cylinders. be sure to check your line! I have seen lines plug up with debris, or the ermeto sleeve(ferrule) crush the line down closing up the hole. PSB heads are not readily available new from ambac, but we have had success sending them out to be remanufactured. Best to find a good used one. good luck! Ed.
tom
Posted: 24 Sep 2010 at 2:38am |
it's not the injector i have tested it. took the injector pipe off of no.6 and no.2 cranked the tractor over and would get diesel shot about 6 or 8 inches in the air but no. 2 would just dribble about half the volume. the tractor runs real good just, not on no.2. I have put new rings, got head done, injectors done, new clutch, new bearings, would really like to get her running 100% after putting a good deal of time and a lot of bucks into her.
Michael Crowe
Joined: 11 Sep 2009 Location: Kansas City Points: 1749 |
Posted: 23 Sep 2010 at 9:34pm |
Since the Bosch PSB pump only has one plunger, it can't be the pump that is not pumping on only one cylinder, it has to be your injector. if it were the pump, it would do the same for every cylinder.
The 15th Annual Exclusive AC Swap Meet will be held in Boonville, MO, March 6-7, 2026. See the club website for details: http://www.moacclub.com/
TramwayGuy
Joined: 19 Jan 2010 Location: Northern NY Points: 11858 |
Posted: 23 Sep 2010 at 9:24pm |
Have you had the injector tested on #2??? If it is stuck, putting another pump on it would not be good. |
j.w.freck
Joined: 16 Sep 2009 Location: karnack texas Points: 1153 |
Posted: 23 Sep 2010 at 9:10pm |
call jim at the turbo shop in blanchard louisiana.he has worked on injection pumps of all kinds for 40 years.took my psb pump to him and had it and the injectors run.works like a new one
Chris/CT
Joined: 11 Sep 2009 Location: Niantic, Ct Points: 1939 |
Posted: 23 Sep 2010 at 7:44pm |
Have 3 pumps here if you need another. 860-306-5946
Butch(OH)
Look up Ferguson diesel service, Austin MN and ask David. Not sure if he is still working on pumps or retired, he can either fix it or reccommend someone that can. |
tom
Posted: 23 Sep 2010 at 4:15pm |
still havingtrouble with my 45d pump. brought it to a diesel shop charged $150 told me they found a valve stuck and it was ok. it still wont inject on no.2 i could almost swear on my life they never even looked at it. can the head unit be repaired? Gonna try and get time to remove the pump and have alook at it myself. Any help with what to look out for would be a great help. fed up with guys taking the P***
