PS Pump
BrianC,Ont View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Topic: PS Pump
    Posted: 19 Oct 2011 at 9:39pm
I need a Barnes ps pump like this. It lists this pump as used on a diesel. It is on a D17 Series II gas. The pump drives off the back of the generator. I am on my way to Calgary area, if anyone out that way has one. I have lots of 6080, and some D17 parts to trade.
35WC on steel, B with belly mower, D17 puller, D15 Series II puller, D15 Series II with loader, 608 Lawn Tractor
KenBWisc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2011 at 8:40am
Brian,What is wrong with your pump? I had mine for a D-19 rebuilt at  a local machine shop with seals and shaft work for WAY less money than even a used one that needed similar work.
'34 WC #629, '49 G, '49 B, '49 WD, '62 D-19, '38 All Crop 60 and still hunting!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2011 at 1:08pm
That pump looks the same as what's on my D17D. If you have a pump on the back of a generator on your gas D17, my guess is someone has put together a conglomeration to fix the P/S in the past. All of the P/S pumps I've seen on gas D17's engines is either sandwitched between the governor and distributor or belt driven like a WD45.
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2011 at 8:08pm
same pump on a wd45 diesel
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2011 at 7:24pm
I think that this is a D17D setup, I was hoping I could locate a pump. I bought a complete Series 4 ps setup, but dont have the time to change it, and want to get the loader back on. I hope I can locate a pump on this trip out to Alberta.
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2011 at 7:52pm
  are you sure your problem is only the connec tor between the pump and generator [splines are worn out]  we carry the connectors   1-800-254-3116
  check all splines???
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2011 at 10:13pm
The spline is ok, the pump housing and the rotors have some pretty deep chunks out of them.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2011 at 6:35am
Someone told me that the generator/pump setup is the same as a 56 Chev car.
Maybe something is available from Year One or NPD etc.
