PS Pump/Project for Anyone?
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Topic: PS Pump/Project for Anyone?
    Posted: 09 Apr 2010 at 8:44am
I have this nice compact PS Pump off a Trooper that I believe would be ideal unit for someone needing pump supply. I was thinking of build adapter off Gov. drv. plate for CA? Ly old CA WF was a bear to steer. It also could be easily fabed to mount with belt drive, oils supply can is plastic, small metal tank is easy option also, anyone want to try it? I will sell low $$ to anyone wanting to give it a try, Chris/CT
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2010 at 8:48am
I have a picture from Paul B which shows the M+W PS/Hyd pump mounted to dist. drive housing on a CA? I may try a scan and get it posted here, have bad luck with scan posts.
This page was generated in 0.453 seconds.
