Protect your Allis tractors from Ethanol |
Author | ||
Lonn ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29817 |
![]() ![]() ![]() ![]() ![]() Posted: 30 Jun 2021 at 7:31am |
Wink I am a Russian Bot |
Sponsored Links | ||
Biodieseltoo!https://youtu.be/0phE-t7ddH8
Edited by Lonn - 30 Jun 2021 at 9:29am |
PaulB ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5105 |
There's nothing wrong with ethanol if the carburetor is properly jetted for the correct needed air/fuel ratio and you don't allow it to go stale. I run E85 in my spark ignition pulling tractor for more HP and to eliminate overheating problems. So what if it has fewer BTUs per gallon and needs more fuel per run, It's way cheaper than racing gas on which engine will run hot. I'd run pure ethanol if I could get it.
If it was cost effective, I would use it in a working tractor that I ran regularly, just maybe not a show queen that only went on a off a trailer ever few weeks. Gas engine trailer queens should have their tanks and complete fuel systems drained and dried between uses along with a desiccant sock in the tank to absorb whatever moister gets in there while being stored. Bio diesel is probably OK if used on a regular basis and not allowed to set for days or weeks in the tank. It just has fewer BTUs per gallon than petroleum diesel and has cold weather issues, that must be dealt with. As with anything, if used as it's intended, there aren't problems.
Edited by PaulB - 30 Jun 2021 at 3:01pm |
And farm tractors and combines sit a lot, especially those in collections. That is my point......Protect your Allis tractors from ethanol and biodiesel. In Minnesota you don't get a choice for diesel. It's all bio and it is illegal to have non bio delivered from Iowa which I checked into since I'm not that far from Iowa. I've had three pumps rebuilt because of biofuel and ruined a carb off a simplicity that sat a couple years. Good fuel wouldn't do that.
victoryallis ![]() Orange Level ![]() Joined: 15 Apr 2010 Location: Ludington mi Points: 2878 |
Lonn
Ethanol is an excellent cleaner sounds like you had less than clean fuel systems. If it adds $.20 to a bushel of corn I’ll gladly deal with it. Besides only gas motor I rely on is pickups and the lawnmower. |
Less than clean can be just sitting with a vented fuel tank over winter. No thanks
Clay ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Udall, Kansas Points: 9886 |
Ethanol SUCKS!!!
I can get by with it, as long as I am not doing heavy work. Hard on rubber parts of the fuel system. It does have good cleaning qualities. Not as many BTU's generated as pure gasoline. I often mix some 100LL into my fuel. This helps when doing heavy work. Do not use 100LL in systems with oxygen sensors or cat converters. |
Tbone95 ![]() Orange Level Access ![]() ![]() Joined: 31 Aug 2012 Location: Michigan Points: 12185 |
Yeah, but what motor oil should we use? And do you use calcium chloride in the tires??
![]() ![]() So, we have one guy saying less BTU's generated than pure gasoline, but another uses it for pulling for more HP. No wonder I'm confused.
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 87853 |
I bought a new F250 in 1989... at that time 90% of the gas sold in Illinois was E15 .... Been using it in cars/ trucks / mower/ chainsaw /tractor for 30 years.. No real problems.. Tractors set from Nov till April in the barn.
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
There is no such thing as "Good Fuel" these days. It doesn't matter if it has ethanol or not, if you plan to leave it set for 2 years, figure on rebuilding the carb or flush and drain it before parking. I don't and won't use bio diesel in my flatbed, because it sets a lot and it's way easier to fill it with real diesel before I park it, instead of trying to drain the bio out and flush it. Edited by CTuckerNWIL - 30 Jun 2021 at 5:22pm |
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21899 |
I have had six (80-84-88-93-99-03) F-150 Ford pickups. I have logged over a million miles on all of them. They have always used E-10 exclusively. I have never had one minutes downtime or repairs due to E-10. I use it fairly regularly for the last eight Summers on my WD45. Again, not one bit of trouble. I have no plans to change my operation. I do NOT use any ethanol on my lawn mower. All of the cars I have owned ( eight of those) have also exclusively used E-10 since 1980 with zero troubles.
DougG ![]() Orange Level ![]() Joined: 20 Sep 2009 Location: Mo Points: 8355 |
Not sure on ethanol- but the bio diesel crap will make a mess on fuel systems - they can make rocket fuel - and this stuff is junk , but could be an underminded plan
AaronSEIA ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2573 |
I just run the stuff. E10 never an issue fuel related that wasn't my stupid fault. Like the old manuals said "buy clean fuel and keep it clean". AaronSEIA
AC720Man ![]() Orange Level ![]() ![]() Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5232 |
10% ethanol causes my check engine light to come on my 2006 Durango. A can of Seafoam and a fill up of non ethanol cleans it back up and the light goes off. I also do not like it. Makes small engines run hot. Never run it in my tractors, garden or farm. I know it benefits corn farmers but I don’t like the stuff. I just pay more for what I consider a better fuel.
E10 may be ok for mowing, raking and light work. You really need better fuel if you are doing heavy tillage such as plowing.
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8628 |
I don't like a da*n beauracrat telling me what I can buy. Can still get straight #2 for the diesels that set from fall till spring. Gladly pay the extra cents. About 5yrs ago my supplier told me they can no longer get non alcohol gas from refinery. It's blended at the rack so my small engines and WD/WD45 get that.
DaveKamp ![]() Orange Level Access ![]() ![]() Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6069 |
And both are true. A given volume of 100% Ethanol has about 67% of the fuel energy as an equivalent volume of gasoline. Per gallon, gasoline exhibits around 115,000btu/gal, while ethanol yields 78,000btu. When a competition engine is built, it's operation is optomized for the specific energy density and combustion profile of a specific fuel. Once the engine is running in a proper state of tune, the output is determeined by how much fuel and air is crammed in. To make the ethanol-powered competition engine meet or exceed a gasoline engine, it needs to be fed more. The contrast, is simply to make the gasoline engine do the same... more fuel, more air, more output. All the rest, is just details. The biggest problems with ethanol, is 1) It is voraciously hygroscopic... it draws moisture from the air... and 2) it has propensity to adopt impurities which attack fuel system components. Neither of these characteristics make it good for ANY long-term storage circumstance. The hygroscopic nature can be quickly witnessed by pouring a sample into a clear glass jar, poking holes in the lid, capping it, and placing it on a shelf. As it absorbs water from the air, the LEVEL in the jar will rise as it 'invites' in more moisture. Contrary to advertisement, ethanol blended fuel isn't 'clean'... it has a propensity to yield a high level of formaldehyde, acetaldehyde, and ground-level ozone.
You guys that like bio crap, have at it. Run all you want but quit electing asshole politicians who force me to run a
Yes, aware of these facts, except what I highlighted in red. Does that not mean, you could still tune and set up a given engine on gasoline to outperform what you just set up on ethanol?
BrianC ![]() Orange Level Access ![]() Joined: 16 Jun 2011 Location: New York Points: 1619 |
I haven't had problems with modern cars or modern garden tractors with the E10. I am sure it is more corrosive than pure gas. With the generators or old gas tractors, I drain the carbs bowl, then I fill with something else. That being WD-40, Marvel, ATF, fogging oil. I used them all, seems to work, but who knows if I am really helping out. When time comes to use the equipment, I drain the oil from the bowl, and let gas flow to flush the carb. Has been working for me. However it seems dumb for each owner to invent their own ritual. Somehow in my brain I got the idea that a light oil in the carb would be better than letting it sit dry. While living in California, I did take a batch of E10 Chevron regular and determined it contained 14% ethanol, not 10%. Right now I can't recall how I did that. But I used to be handy in chemistry and lab techniques. So my question is, for running E10-E15, if you have a fixed jet carb setup (from the days of real gas), should we drill out the main jet to let it pass more fuel? The area of the jet's hole should be increased by... 5% or so? Question #2, for any gas tractor, how do you know it is jetted spot on? I have read half-assed procedures , they all seem so subjective, reading plugs, listening to feel how engine accelerates and things of that nature. Aren't there exhaust gas analyzers? |
The point is that it is corrosive and damages fuel tanks and carburetors. 10%, 15% or 85%, it doesn't matter. I don't run dirty fuel. I run clean fuel except biofuel is dirty as soon as they add the bio. That IS the contamination to start with. So anybody who said "sounds like you had less than clean fuel systems" with all due respect YES TRUE. IT HAS BIO IN IT AND THAT MAKES IT UNCLEAN period.
Why do gasahol fuel barrels get the black coating on them? It is worst where the vent is.
when you drive by a farm site with fuel tanks in view,you can tell which one is the gas barrel
HD6GTOM ![]() Orange Level ![]() ![]() Joined: 30 Nov 2009 Location: MADISON CO IA Points: 6627 |
I've been using it in everything since 1977. Chain saw sits for months on end and has never failed to start.
Well the Stihl dealer recommends to not use ethanol. But maybe because your chain saw fuel is a 30:1 or 40:1 or 50:1 mixed with oil it stands a better chance. I won't run ethanol in my chain saw or trimmer ever. I had a Poulan that was always a hard starter from new but I ran ethanol in it and then I caught it in fire using ether to try and get it started. It was only 3 years old and I was glad to see that hard starting @!%#@! burn. That's when I bought my Stihl and I blamed Poulan for the hard starting while my Stihl at 10 years old has been stellar and it has cut a heck of a lot of wood. Maybe it was the fuel because I listened to the Stihl dealer and have always ran non ethanol. It hasn't been run for over a year because of my back and hip issues but I'd bet last month's salary it will start right up if I go try it tonight.
WF owner ![]() Orange Level ![]() Joined: 12 May 2013 Location: Bombay NY Points: 5022 |
Sorry that I'm getting off topic here.
When I bought my 250 Stihl, I was telling the dealer that the biggest problem I have is that the saw sits unused for long periods of time. On my old saw, it seemed that I was cleaning the carburetor every time I wanted to use it. He recommended using the premixed gas/oil. If I am using it a lot, I sometimes mix my own, but when I am finishing up, I make sure I go back to the premix. I also started doing the same thing with my Stihl string trimmer. Since changing to the premix, I have never had to clean a carburetor. It cost a little more, but it is worth it to me.
