pros/cons
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Topic: pros/cons
    Posted: 03 Apr 2013 at 10:34pm
What are the pros and cons of putting a CA transmission in a C tractor?
Thanks
www.awtractor.com
A&W TRACTOR 920-598-1287
morton(pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote morton(pa) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2013 at 10:50pm
Well, the CA was quite different from the C from the torque tube back.
If your just specifically speaking of the transmission, it would be the addition of 1 gear.
Other then that, differences include final drives that accommodated the hand clutch, an all new hydraulic system, the Pin Hitch/Snap Coupler/Traction Booster hitches, etc. just to name a few...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2013 at 11:15pm
Will the PTO turn at a different speed? Would the B/C PTO housing bolt to the CA transmission? I do realize that I would have a CA serial number. The main reason for the upgrade would be the addition of a road speed gear.
www.awtractor.com
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2013 at 12:25am
I believe the PTO housing is the same but there are much more knowledgeable people on this site.
Allis Express participant
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2013 at 8:25am
If you get serious about it, get a parts book for both of them.
Dusty
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2013 at 9:59am
Morton said it; a CA tranny will give your C one more gear. The CA tranny was prone to wear one 3rd gear and many jump out; very expesive to fix. The B/C/CA share many parts and it is not uncommon to run into one that has had the parts interchanged. A link to a PDF file on the B/C/CA tractors below.
rpropst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rpropst Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2013 at 4:02pm
 I may be wrong but I think the extra gear in the CA transmisson will give you 1 lower gear. I think my B will run as fast as my CA in top gear.
1950 snap coupler B 1948 WD 1951Ca 1952B 1952adjustable axel B
George Davenport View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote George Davenport Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2013 at 4:08pm
A post reply a few days ago addressed this topic, and revealed that top forward speed of the B is 7.8 and the CA is 11.3.
Life is what happens while you are making plans for the future
Post Options Post Options   Thanks (0) Thanks(0)   Quote George Davenport Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2013 at 4:22pm
Further information of interest was posted by CTuckerNWIL on 29 Mar and topic was titled "Looking for Project-questions".  It was very informative.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rpropst Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2013 at 4:52pm
B and C is rated at 1500 rpm CA rated at 1650 rpm. CA rated with 10-24 tires B and C rated with 9-24 tires
Edited by rpropst - 04 Apr 2013 at 5:07pm
This page was generated in 0.477 seconds.
