Propane WC |
Freewheelin ![]() Silver Level ![]() Joined: 29 Sep 2009 Points: 60 |
![]() ![]() ![]() ![]() ![]() Posted: 30 Jun 2015 at 10:23am |
http://madison.craigslist.org/grd/5099855721.html
NICKMI ![]() Orange Level Access ![]() ![]() Joined: 15 Sep 2009 Location: Greenville Points: 534 |
looks like a wd45 to me
desertjoe ![]() Orange Level Access ![]() ![]() Joined: 23 Sep 2013 Location: New mexico Points: 13681 |
How do you guys get the posted links to open,,,??? |
I did it the hard way went to Craigslist went to wisconsin then Madison and then I searched allis chalmers there's gotta be a better way right ?
BennyLumpkin ![]() Orange Level ![]() ![]() Joined: 22 Mar 2010 Location: Centre Hall, PA Points: 2657 |
Central PA Allis Express
1934 WC254 1945 WF 1945 WC135755 1951 WD68085 1953 WD45-150217 1957 WD45D-230744D B110 |
Kenny L. ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: NEIOWA Points: 1328 |
AaronSEIA ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2564 |
Definately a WD or WD45. Aftermarket, right? I thought the OEM propane ones had the tank out front. Whats up with the cap on the air cleaner?
AaronSEIA |
Gatz in NE ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Lincoln, NE Points: 1043 |
Benny, something about your link results in a 404 error.
try this http://madison.craigslist.org/grd/5099855721.html is that propane tank from a D series ? it has some kind of hood over the gauges/filler Edited by Gatz in NE - 30 Jun 2015 at 4:49pm |
Tim NH ![]() Orange Level Access ![]() Joined: 16 Oct 2012 Location: Lancaster NH Points: 1118 |
Joe, how I do it is, put the pointer at one end of the address, left click on it and hold it down till you get to the other end. Mine turns all blue, then put the pointer in the blue and right click. It will ask you to search it w/ what ever search engine you have installed. Click on it, and you'll find it. I hope this was what you wanted. Tim
Unit3 ![]() Orange Level ![]() ![]() Joined: 17 Oct 2009 Location: NC Iowa Points: 5571 |
I thought the tank was out front on the WD and WD45.
Bill_MN ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Sioux Falls, SD Points: 1466 |
Tank was out front on factory propane models, this is a field-installed dealer option tractor.
jiminnd ![]() Orange Level ![]() Joined: 16 Sep 2009 Location: Rutland ND Points: 2271 |
I think the air cleaner cap is a dry paper filter added, my brother got his fil D17 with a similar lokking filter, had trouble for a few years getting it to run right, tried several things them dicovered the paper filter that looked like it had never been changed, threw it away and problem solved.
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22824 |
HIGHLIGHT the posted link, then right click on it and click open in a new tab. |
In the one pic of the distributor, you can see the block is cast all the way down the right side. Gotta be a 226 block.
