Propane water heater quit??
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Topic: Propane water heater quit??
    Posted: 20 Jul 2019 at 2:37pm
Girl friend has an AO Smith Promax water heater around 10 years old , 40 gallon model and it just quit, propane tank has 40 % in it -when you try to light the pilot light there is no hiss of gas, no smell at all , igniter is sparking but no flame happens where its supposed to , we are going to replace it but Im a fixer and just curious on what happened to it ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2019 at 2:45pm
any other propane appliances on the tank you can try to be SURE you have propane ?
Dave in PA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in PA Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2019 at 2:51pm
Try a new Thermo-coupler,  cheap and first place to start.  it is the little thin wire looking thing going to the gas valve, and the pilot light/ or maybe a electronic thing now??  I am not sure about the newer stuff, with-out the flames.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2019 at 3:16pm
Everything else works,, I thought about the thermocouple,,, used to live in a trailer and kept them on hand, but that was in the 90,s
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2019 at 4:24pm
Be careful. Propane more hazardous than NG. A coworker spent ten days in the hospital doing what you are doing. That said, is the gas control in the pilot position and held down while you are attempting to light pilot? If I remember correctly that model has a sealed door to the burner chamber and you likely won't hear gas entering. Can you see the spark ? If so the the gas control valve is suspect and would need replaced.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2019 at 6:49pm
Probably the regulator if you ain't getting gas for the pilot.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2019 at 7:20pm
Check to see if your getting gas to the water heater.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2019 at 9:07pm
Since it has an ignitor does it even have a pilot light or just fire off when the thermostat calls for heat? May be a bad gas valve.
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2019 at 9:23pm
The newer ones with the igniter that you have to push each time to make it spark usually have closed chambers so you won't smell any gas.  I just had to replace thermocouple on MIL's water heater, dang part had been hanging on the wall in the shop for over 10 years.  Had to take the whole burner out to replace it and be very careful with the grommet the thermocouple goes through, it could break apart if you aren't careful but hi-temp silicone will work if you do.  Which reminds me, I need to go back there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2019 at 10:01pm
Is it a power vent model where it has a blower on top and plastic vent pipe ?
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2019 at 11:17pm
Pat can help...I know from experience....owe him a nice dinner now...he's a good guy....
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2019 at 8:28am
No blower or plastic cap on this one
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2019 at 8:59am
the blower would be a permissive to startup......... Since no blower you are back to the original... You got SPARK, but no light off..... so you have no GAS..... similar to a tractor at this point.........
Most of the gas valves / regulators / will have a button to PUSH to bypass the thermo probe and let a small amount of gas thru the valve... and this starts the pilot light.. PIlot runs until the thermo probe warms up and send signal to the gas valve to STAY OPEN.
Do you have a PUSH button for the bypass  startup ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2019 at 9:01am
another idea... I once worked on one ding similar to what you say... Looked and the gas line was constant run down hill into the gas valve... Piece of rust / crud had fallen down from the sloping line ( even tho it was copper) and got PLUGGED at the gas inlet orifice.
Fat albert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fat albert Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2019 at 9:47am
Unscrew pilot line from valve. Push down pilot button you schould here gas. If you don't it's a gas valve issue.if you. Do its either a dirty pilot office or misaligned igniter. Be careful.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2019 at 10:51am
Check thermocouple - they can corrode where they contact workings of the gas valve or also just fail to produce the mini-voltage needed to operate gas valve .
 Had one on natural gas where the internal wire on coil broke and thermocouple would not turn on rest of valve workings
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2019 at 4:21pm
It has the push down gas valve to ignighte the pilot, no resonse
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2019 at 10:18am
Yep, first the thermo coupler.  Second, since you can't hear gas,,,,,,,,check where the ignition is.  I've had spiders build a nest it there and won't allow any gas to come through.  Took my air compressor to the line (LOOKOUT!!)  There is a SMALL orifice in the line that you don't notice and it sailed across the room, hitting the wall and then what??!!  Thank God we had hardwood floors as we found it.
Anyway, blew out the line and saw the spider web (cocoon??) and used a wire to get the rest of that out.  That stuff is STICKY!  Put it all back together and it's still working fine.
This page was generated in 0.992 seconds.
