Progress is starting on my HD5G
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2016 at 12:12pm
most likely trans interlock to prevent shifting when clutch is engaged
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2016 at 1:15pm
This rod is the plunger lock the gear shift
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2016 at 11:53pm
Darrel, any luck getting the clutch out?
Allis Express participant
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2016 at 6:20am
Yes, John. The clutch is out. Had to do some bearings in the final drive, though, and haven't had time to work on it in forever. Had better get to it soon, though, because I need it for some corral cleaning and have lots of money worth of bearings and clutch parts tied up just sitting there. Probably would get done faster if I just hauled it out to California and had Mel and his Crew do it. Lol Darrel
treedog62 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote treedog62 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2016 at 12:24pm
need the front bearing on trans! where can I get one at! cant find the part no on the old bearing! and its all to pics!! any one have a part no? thxs
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2016 at 3:49pm
The bearing ball input shaft front 042847
Post Options Post Options   Thanks (0) Thanks(0)   Quote treedog62 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2016 at 5:17pm
042847 bearing! nothing shows up when I search for that bearing!! any other no's. lol thxs got no's off the other bearings and got them thru ebay!  thxs
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2016 at 5:35pm
In my parts manual for the front input shaft is 042847 and the rear input shaft 050270
Post Options Post Options   Thanks (0) Thanks(0)   Quote treedog62 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2016 at 4:50pm
the old rear ones I took out has different part no!! hmmm!! dang it! I ordered 2 on ebay but the front one dosnt show any thing!! thxs
dadsdozerhd5b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2016 at 8:57pm
those numbers are the allis part numbers. sometimes they change sometimes they do not and you need to order from dealer. check your local bearing supplier first as they have a lot of interchanges. good luck.
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2016 at 2:39am
guess that must be one thing you need brakes on...huh?
Ian Beale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2016 at 2:52am
TD
Try putting a 7 in front.
Or find someone who has an OLD IBR Bearing Exchange book.
One of our locals has one and it goes straight from the old Allis part number to equivalent if such existed at the time of printing.  Which can lead you up to now.
Even got me nla Torrington rollers for the steering box of an AC 45 straight to current number.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2016 at 9:46am
The front input shaft bearing jobber is FEDERAL 1209
This page was generated in 0.852 seconds.
