Print Page | Close Window
How Do You Hog With The Older AC's
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=55026
Printed Date: 08 Jan 2025 at 12:34am
Topic: How Do You Hog With The Older AC's
Posted By: PlayGun
Subject: How Do You Hog With The Older AC's
Date Posted: 09 Aug 2012 at 11:25pm
Just wondering how you guys bushhog with the older AC models,like a C or B because they don't have a 3 point? And if you got a pic of your setup it would be great. I think I got what I am going to do figured out. I am going to buy a D17 or a 170 gas and then have an older C, B, or WD to bushhog with, that way I will have an excuse to have 2 AC's the only other thing I thought of was getting the D17 or 170 and buying a small oliver 550 or such. That way I can use the little tractors to hog with or spray and just whip out the big boys when I'm baling. I am sure the little guys will pull a hay rake good as well.
Hopefully Future AC Man! Ride With Jesus my friends!     Lonas
Posted By: CTuckerNWIL
Date Posted: 10 Aug 2012 at 6:13am
You either add 3 point to the tractor or you buy a trailer type mower. I have an old JD gyromor that I pulled behind the 35WC this spring. I have the cylinder blocked to hold it at mowing height so I don't NEED hydraulics.
Posted By: Mike_426
Date Posted: 10 Aug 2012 at 6:40am
I pull a king cutter pull type i have a ratchet binder on mine, keep greased it'll be easy to adjust up and down.
G, 200, 8050 mfd, D17, 195 chainsaw, c-wide front
Posted By: Morgan in AR
Date Posted: 10 Aug 2012 at 6:57am
I've done some brush hogging with my ca, I used a 5'pull type.  It works pretty good for pastures, but the no floor pan makes it a little hairy for heavier brush. BTW I think you're looking at a pretty big price difference between an oliver 550 and a b or c.- Morgan
If we loose freedom here there is no place left to escape to. This is the last stand on earth. -Ronald Reagan
Posted By: Jim Lindemood
Date Posted: 10 Aug 2012 at 7:16am
Depending on your terrain -- you can use a pull type hog. I have an older AC model that I have pulled behind a D17D and a 185 - probably more tractor than it needs, but works just fine on the rolling fields. (same model OldDoug posted pictures of) Have a 5'  3pt Bush Hog that I use on an AC5030 -- need the 3pt to lift up when crossing some terrain.
To get to some fields, have to go down road a little bit -- but still use the pull behind and drive on down the road. But that is no excuse not to have two tractors -- or 3 -- or 4 -- or ????   - LOL.    Also - use that 5030  with hay rake and finish mower.
Posted By: EdK
Date Posted: 10 Aug 2012 at 9:23am
Put a 3 point on your B or C and you will have a load of 3 point implements you can get.
Posted By: JimD
Date Posted: 10 Aug 2012 at 9:42am
Yep, the three point opens up lots of opportunities, but it can certainly be done with a trailer type. Done both, and honestly, depending on terrain, sometimes the trailer is beter.  But the 3 point setup has real advantage in tighter areas.
JimD
Owner of http://www.OKtractor.com" rel="nofollow - OKtractor.com PM for an instant response on parts. Open M-F 9-6 Central.
We have new and used parts. 877-378-6543
Posted By: MilesGray (CO/KS)
Date Posted: 10 Aug 2012 at 9:45am
I have a home made 3 point on mine. it allows it to work but doesn't move so it acts more like a deck mower. Now that I put new rings and pistons in it, it really goes to town! Just wish it would rain around here so I can really use it! lol
It has 2 3/8 inch angle iron bars that run from the seat frame to the drawbar and the arms are attached to that. It is the greatest setup I've ever had, run the bigger trees under the final drive and the brush hog eats them up! I bought the whole setup for $1000.00 2 years ago. I don't need a bigger tractor for my 12.5 acres.
Miles Gray (CO/KS)
5 1938 B's, 1940 B, 1944 WF C, 1948 NF C, Gleaner A, White Top Rotobaler, 1957 IH Golden Jubilee... I'm either a collector, or crazy!
Date Posted: 10 Aug 2012 at 9:48am
EdK, what's the hose for that runs from the back of your tank to the gas cap?
Miles Gray (CO/KS)
Posted By: Embellem
Date Posted: 10 Aug 2012 at 1:13pm
I have a King Kutter pull type that came with the farm. Cuts fine, but doesn't maneuver as nicely as a 3-point mounted one would.
From what I've seen, good Oliver Super 55s and 550s aren't cheap. Could probably get two good smaller ACs (B-C-CA) for what one Ollie utility would cost.
Posted By: DiyDave
Date Posted: 10 Aug 2012 at 8:15pm
Best AC tractor/bush-hog combo will always be a D-14 tricycle with a 160 snap coupler bush hog, and the original height adjusting rooster comb.  Just my humble opinion.  It had the balance, just right, and the bush hog was the same width, as the narrowest wheel setting of the D-14.  I could pee, drink a beer, and shoot a groundhog, all at the same time, on flat, level ground!
Posted By: JohnCinMd
Date Posted: 10 Aug 2012 at 8:21pm
i use a 5ft pull behind with my WD. It's a lot of fun, except when I have to steer around the perk test holes.
Date Posted: 10 Aug 2012 at 8:23pm
I did put on a PTO clutch since that picture was taken.
Posted By: DREAM
Date Posted: 10 Aug 2012 at 9:38pm
Dave, you are talented sir! I'd get all confused and end up peeing in my beer! Course, the land aint quite as flat around here. We stay pretty busy dodging rocks, holes, and gulleys.
Anyhow, here is a pic of my C with the trailer bush hog that my grandad used behind it. Driveline needs rebuilding in a bad way. Flops and bangs all the way through any turn over 5 degrees. Does a nice job though.
I didn't do it! It was a short, fat, tall, skinny guy that looked like me!
Posted By: jb from md
Date Posted: 10 Aug 2012 at 9:49pm
put this up before but here's a my 49 c and a 6 foot woods
8050 FWA, 190XT, 185, Styled wc, Unstyled wc, (2)C, (2)WD45NF, WD45WF, WD,416h, 716h, 312h, 8070 pedal.
Posted By: DREAM
Date Posted: 10 Aug 2012 at 10:05pm
You got engine weights JB. I'm jealous! LOL!
How does the C handle that 6'? Mine is a 5' and goes through thick and tall grass and brush with no problem in first gear. Cuts pretty good in second. No lack of power, but the ride is a little rough on the kidneys.
Date Posted: 10 Aug 2012 at 10:12pm
it does alright, i use second gear but i keep after it so it doesnt get too tall... the mower came with the tractor when i bought it, and the guy i got it from used it to mow about 5 acres a coulpe times a year . i hac the c hooked up to the water tank i used to water my sweet corn and garden so i put the mower behind the wd45 . it handles it better in the couple feet tall grass....Jb
