Wix 33354 on XT
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=48648
Printed Date: 25 Aug 2025 at 10:48pm Software Version: Web Wiz Forums 11.10 - http://www.webwizforums.com
Topic: Wix 33354 on XT
Posted By: captaindana
Subject: Wix 33354 on XT
Date Posted: 08 Apr 2012 at 11:15am
for fuel filter. It say's secondary. My questions; is this the correct fuel filter for the XT III and why does it say secondary...do/did they consider the sediment bowls primary? Thanks and Happy Easter. Dana
Posted By: injpumpEd
Date Posted: 08 Apr 2012 at 1:28pm
secondary means final filter, lower micron rating. Typically around 5 micron. On these tractors, it is the only real filter though, so the primary would be the sediment bowls/screen.
------------- 210 "too hot to farm" puller, part of the "insane pumpkin posse". Owner of Guenther Heritage Diesel, specializing in fuel injection systems on heritage era tractors. stock rebuilds to all out pullers!
Date Posted: 08 Apr 2012 at 2:45pm
Thanks. So can anyone verify if this WIX number is correct? I am trying to verify everything being correct before removing pump again.
Posted By: iranch(SESD)
Date Posted: 08 Apr 2012 at 4:28pm
That's the one I use. There are others that very only in the length of the filter and would also be correct. The 33354 is the short one and easiest to get started and tightened on the 190's I have loaders on, so I use it for all the ones I have. The longer versions would probably last longer before plugging, but I don't have a problem with that. Most get replaced because it's been so long, not because the plug.
Dennis
Date Posted: 08 Apr 2012 at 4:59pm
Thanks guys. When I took out the sed bowls their inlets had corky looking crap in them. I have proved all lines are good and they're back together. When I run her again we shall see if she still seems starving for fuel. Hope not.
Posted By: Jim Lindemood
Date Posted: 09 Apr 2012 at 7:37am
Wow -- you are doing such a great job getting all your tractors ready -- when you are done and bored, feel free to come out and do mine -- LOL
