D17 died
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=47611
Printed Date: 29 Aug 2025 at 3:06am Software Version: Web Wiz Forums 11.10 - http://www.webwizforums.com
Topic: D17 died
Posted By: WilliamNEOH
Subject: D17 died
Date Posted: 20 Mar 2012 at 6:48am
about 30 minutes use. Was going uphill, govenor kicked in, turned off the road and depressed clutch to down shift and just died. Back to the house grabbed the 14 and towed her home. An hour later checked fuel line, getting fuel, starting checking for spark and acted like it wanted to start so turned gas on and fired right up. I'm thinking coil, Sound about right. And what is the large nut on the back of the distributor for?
------------- CA,WD-45,D14&D17
Posted By: TexasAllis
Date Posted: 20 Mar 2012 at 6:57am
WilliamNEOH wrote:
about 30 minutes use. Was going uphill, govenor kicked in, turned off the road and depressed clutch to down shift and just died. Back to the house grabbed the 14 and towed her home. An hour later checked fuel line, getting fuel, starting checking for spark and acted like it wanted to start so turned gas on and fired right up. I'm thinking coil, Sound about right. And what is the large nut on the back of the distributor for? |
Sounds more like a fuel problem, something floating around in the tank or trash in the carb. Ever coil I ever had that went bad did so right away.
------------- 1944 Allis C 1960 Allis D-17 LP
Posted By: Stan IL&TN
Date Posted: 20 Mar 2012 at 7:19am
If it happens again pull the drain plug from the carb. and see if you have fuel. If no fuel then it's fuel supply problem or float. Do it right away not an hour later. If plenty of fuel flows then look to ignition.
------------- 1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Posted By: NickT(Ky)
Date Posted: 20 Mar 2012 at 8:16pm
My D-14 does that sometimes on a hot day. I think it vapor locks cause I can loosen the fuel cap and the tank breathes. It will start right up after that. On a hot day after a parade I just leave the fuel cap (it is a new one) a little loose.
Posted By: Chalmersbob
Date Posted: 20 Mar 2012 at 8:27pm
fuel cap should have internal vent, Bob
Posted By: stray
Date Posted: 20 Mar 2012 at 8:30pm
Nick did you buy the fuel cap because of this problem or did it start after you got it. It sounds like your tank isn't vented right.
------------- 1969 190XT series 3
Posted By: cornbinder
Date Posted: 21 Mar 2012 at 6:43am
i 2nd that motion. sounds like a venting problem.
------------- D-19 gas w/f-sold 185-d yr round cab 95 mustang gt 5.0 86 mustang 5.0 coupe 3 99 f-250 7.3 4x4's 96 f-250 7.3 4x4
Posted By: JayIN
Date Posted: 21 Mar 2012 at 6:48am
FUEl. in 35 years of working on this junk I have found 1 bad coil. They rarely go bad.
------------- sometimes I walk out to my shop and look around and think "Who's the idiot that owns this place?"
Date Posted: 21 Mar 2012 at 7:31pm
Had to of been fuel because no issues yesterday and it was ran longer than monday.
