Print Page | Close Window
Wheel weight questions
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=47213
Printed Date: 29 Aug 2025 at 5:48pm
Topic: Wheel weight questions
Posted By: EPALLIS
Subject: Wheel weight questions
Date Posted: 13 Mar 2012 at 9:18pm
I have a 1961 D-17 series II in good condition.  I drained the fluid out of the tires and now find it a bit lite in the rear.  I have one set of the A-C rear wheel weights from a WD and I have another set of the "F&H" rear wheel weights from a WC.  1.
Will either one of these rear wheel weights fit my D-17 series II??
If so, which set is best to use??
Also what kind of bolts (size) should I use??
I obtained the weights at a sale and no bolts were included.  Any assistance would be so much appreciated.  Thanks!!
Posted By: Dave (NE)
Date Posted: 13 Mar 2012 at 9:47pm
I know the ones from the WD will fit.  Have put them on my D17 in the past.  However, they will not be anywhere close to the weight from the fluid in the tires.  They are only 135# each.  I went back to the fluid when I put new tires on the '17.  As for bolts, I'll have to look that up and get back.  Dave
Date Posted: 13 Mar 2012 at 9:50pm
I know the ones from the WD will fit.  Have put them on my D17 in the past.  However, they will not be anywhere close to the weight from the fluid in the tires.  They are only 135# each.  I went back to the fluid when I put new tires on the '17.  As for bolts, they are 3/4 x 3 1/2 carriage bolts.  Dave
Posted By: Dave in il
Date Posted: 13 Mar 2012 at 10:08pm
Either set should work. I've used WD wieghts on D17 and F&H wieghts on the WD45. The holes are the same distance apart. Not sure about the bolts.
AGCO My Allis Gleaner Company
Posted By: Roger Nolin
Date Posted: 14 Mar 2012 at 8:17pm
mount both sets
Posted By: EPALLIS
Date Posted: 14 Mar 2012 at 9:44pm
Dave and Dave:  Thanks so much for taking the time to respond, especially finding the bolt size for me.  This is very helpful and I really appreciate it. Thanks so much.  Going orange is going great!
