shopping success
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=46617
Printed Date: 03 Sep 2025 at 6:55am Software Version: Web Wiz Forums 11.10 - http://www.webwizforums.com
Topic: shopping success
Posted By: dad2many
Subject: shopping success
Date Posted: 03 Mar 2012 at 6:06pm
Well the trip was a success. Had a CA and loads of equipment follow me home older restoration with low hours but sat under a chicken coop Sorry about size, uploading from phone. By the way, current pricing, $2k think I did well
Posted By: dad2many
Date Posted: 03 Mar 2012 at 6:10pm
May need help with what all I got. Got an ih belly mower adapted to fit, a two row plow, cultivators, a single root rake? Spring ripper? Lift handles. And belly tines?
Posted By: dad2many
Date Posted: 03 Mar 2012 at 6:20pm
    Leaving its home since 1979
Posted By: wjohn
Date Posted: 03 Mar 2012 at 6:26pm
Looks like a good haul. The great big curved thing with a point on the end is a subsoiler.
------------- 1939 B, 1940 B, 1941 WC, 1951 WD, 1952 CA, 1956 WD-45
Posted By: dad2many
Date Posted: 03 Mar 2012 at 6:31pm
What's the little one I've leaned against the sub soiler? It has a little snap hook.
Posted By: MNLonnie
Date Posted: 03 Mar 2012 at 6:47pm
I don't see the hand clutch lever. It either didn't come with one or the lever was removed. If it was removed I would guess the hand clutch needs work. Really nice haul you have there.
------------- Waukesha B, B, IB, G, styled WF, D15, 615 backhoe, 2-Oliver OC3's, 4 Ford Model T's, 3 Model A Fords, AV8 Coupe, AV8 Roadster, 1933 Ford Wrecker
Posted By: Hubert (Ga)engine7
Date Posted: 03 Mar 2012 at 6:50pm
Looks like a nice haul. The hand clutch lever on yours seems to be missing. It should be a lever about 30 inches long just inside the right fender. It disconnected the right hand axle shaft to stop the tractor but let the pto continue to run. Many times when these would start to slip they would be bolted together and the lever removed. This eliminated the slip but it also eliminated the hand clutch function also.
------------- Just an old country boy saved by the grace of God.
Posted By: dad2many
Date Posted: 03 Mar 2012 at 7:02pm
There is a little lever laying flat on top but it looks like the hydro lever. There is a little ring lever to the left of that. not sure what it does. I will do more looking tomorrow. Not familiar with these but couldn't pass on the deal.
Posted By: CTuckerNWIL
Date Posted: 03 Mar 2012 at 7:07pm
Nick, what year is she. looks like the later style air cleaner with a pin hitch, might be about 1952 and a half, maybe early 53? Looks like somebody did some heavy lifting to load and unload it all.
------------- http://www.ae-ta.com" rel="nofollow - http://www.ae-ta.com Lena 1935 WC12xxx, Willie 1951 CA6xx Dad bought new, 1954WD45 PS, 1960 D17 NF
Posted By: dad2many
Date Posted: 03 Mar 2012 at 7:22pm
The serial number is CA25065 is this where the hand clutch lever should attach?
Posted By: dad2many
Date Posted: 03 Mar 2012 at 7:24pm
Oh and the loading was easy. The previous owner had a front end loader. Uploading was rough as I have a two hand unloader
Date Posted: 03 Mar 2012 at 9:02pm
CA25065 is an early 53. The hand clutch handle comes out of the right front curved section of the platform. This is kinda far away but to the right of DeWayne's right leg, next to the right fender is the handle.
Date Posted: 03 Mar 2012 at 9:06pm
Here you can see the hand clutch handle easier.
Posted By: dad2many
Date Posted: 03 Mar 2012 at 9:13pm
Yep don't have that lever guess I'll have to find one and figure out if there's an issue. Anybody got one laying around they want to part with?
