Print Page | Close Window
6080 Shifting Issues
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=45491
Printed Date: 10 Sep 2025 at 4:17am
Topic: 6080 Shifting Issues
Posted By: BLee Mn
Subject: 6080 Shifting Issues
Date Posted: 13 Feb 2012 at 11:06am
Have a 83 6080 9000 hours, having problems getting it in to gear, its not grinding but  i would describe as lack of grinding what makes it hard to get in to gear, also hard to get out of gear when on a small incline( trying to get out of a forward gear to reverse) Clutch is adjusted according to book specs. also , if sitting on level ground, step in clutch, move shift lever to engage a gear, tractor will start to move before gear is fully engaged. sometimes can select a gear and goes right in , but most of time its a battle to get in to gear.  You guys got any ideas or advice    Frustrated   Im used to my 190 shifting so nice.   thanx for any help  Brian
Cowboy UP
Posted By: stray
Date Posted: 13 Feb 2012 at 11:16am
sounds like something has come apart in the clutch, pilot bearing dragging. Either way it is splitting the tractor
1969 190XT series 3
Posted By: BLee Mn
Date Posted: 14 Feb 2012 at 8:49am
Bump,  I must have everyone stumped!!!!
Cowboy UP
Posted By: BradinNWWI
Date Posted: 14 Feb 2012 at 9:13am
Just my 2 cents we have a 6060 that we adjusted the clutch and it still didn't act right. We had to put a new cable on it because it was binding up. Worked great after that ours has around 11000hrs.
Posted By: ky wonder
Date Posted: 14 Feb 2012 at 10:48am
i was told the day i bought my 6060, that the previous summer it started having clutch issues, so new clutch assembly was bought and tractor was split, found the original clutch was in good shape it was a cable issue, they replaced everything including the cable and now everthing works great'
this information was given to me by my local tractor mechanic, who has his shop just accross the back fence from me, he did the work and said the old man wanted to go ahead with the new clutch since it was split anyway. but all it really needed was a cable
so i would check the cable first.
i like old tractors of all colors
Posted By: rrhead(SD)
Date Posted: 14 Feb 2012 at 1:34pm
We have also replaced the cable in 2 of our 6080's. Both of them broke so maybe they didn't get wore enough to cause the same problems. rrhead(SD)
Posted By: Ron(AB)
Date Posted: 14 Feb 2012 at 11:51pm
We had a 6070 with the same issues - cable adjustment and cable ends / hooks being worn and worn cable pins.
Posted By: Kevin(Alabama)
Date Posted: 15 Feb 2012 at 8:25am
Brian, Sounds to me like the clutch isnt releasing all the way, even though you have it by the book, I would increase it a little and see what happens. It could also be that cold MinnowSoda winter, lol. My 6080 has 5??? hours and have not had any problems yet. Other than I still need a back glass.
"I would die a thousand deaths before I would betray a friend."...Sam Davis, Nov. 27, 1863.....DEO VINDICE
Posted By: BLee Mn
Date Posted: 15 Feb 2012 at 9:12pm
thanx for all the tips guys, will try adjusting cable/replacing... Kevin, Cant be the weather, its been so nice here this winter, thought i was Livin the Good Life of someone from ALabama.... thats why I havent been down to see ya!!!!!   although if up here, you might want to get that glass replaced!!  LOL
Cowboy UP
Posted By: TobeMo
Date Posted: 15 Feb 2012 at 11:56pm
I bet rusted splines on the input shaft preventing disc free travel to completely disengage. Tobe
