Bucket for d15
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=38866
Printed Date: 24 Jan 2025 at 3:23pm Software Version: Web Wiz Forums 11.10 - http://www.webwizforums.com
Topic: Bucket for d15
Posted By: muddyford8387
Subject: Bucket for d15
Date Posted: 13 Oct 2011 at 12:53pm
Hi everyone, My husband and I recently inherited a Allis Chalmers D15. We have found some information on this tractor through searches on the internet, but he is unsure if we can put a bucket on this tractor, he would like to get one(mainly for snow removal) and recently found a really good deal on one. Any information or advice would be greatly appreciated.
Thank you!
Posted By: AC WD45
Date Posted: 13 Oct 2011 at 2:52pm
Yes, assuming it's the right loader. A #14 loader, or #17 loader would likely fit it dependig on the year. Loaders for these tractors were for most part universal. Also, about any freeman trip bucket loader should fit it. Factory loader
Trip bucket loader
------------- German Shepherd dad 1957 Allis Chalmers WD45 #WD234847 1951 Allis Chalmers WD #WD88193
Posted By: AC WD45
Date Posted: 13 Oct 2011 at 2:53pm
Factory full hydraulic loader (500 I believe)
Posted By: AC WD45
Date Posted: 13 Oct 2011 at 3:01pm
If your tractor has one-way hydraulics, it will only be able to run the trip-type loader unless it is converted to run two way. If it is two way, it will work with a full hydraulic loader.
With a trip loader, there is no "down pressure" so you can not "push" the loader down, gravity does the work. the same with the bucket, only you pull a spring loaded lever to "unlatch" the bucket, gravity or weight inthe bucket causes it tp "dump" Some you have to lower the bucket to the ground to "re set" it, others have return springs. If you get a loader with a 40" manure bucket, in order to efficiently move snow, you will also either need to find a replacement snow-bucket, of find the factory extensions.
I also reccomend some sort of HEAVY ballast (weight) on the back of the tractor unless the tires are loaded, and snow chains, or you will get nowhere when you have snow i the bucket. I also hope you have power steering, or it will steer hard with weight on the front.
Date Posted: 13 Oct 2011 at 4:20pm
Yea we were just having this conversation at dinner about chains and counter weight. Thanks for the information by the way
Posted By: Gary IN
Date Posted: 13 Oct 2011 at 4:53pm
Have a kelly loader in decent shape off D-15 with valve for down pressure and hyd bucket. But located in indiana. Gary IN
Posted By: DSeries4
Date Posted: 13 Oct 2011 at 8:49pm
WD45, The 400 (last picture) is the fully hydraulic loader available for the D15. The first picture you posted looks to be a factory loader with a hydraulic dump bucket added in place of the mechanical trip.
------------- '49 G, '54 WD45, '55 CA, '56 WD45D, '57 WD45, '58 D14, '59 D14, '60 D14, '61 D15D, '66 D15II, '66 D21II, '67 D17IV, '67 D17IVD, '67 190XTD, '73 620, '76 185, '77 175, '84 8030, '85 6080
Posted By: AC WD45
Date Posted: 13 Oct 2011 at 9:09pm
Thanks for clearing up the last one. I wouldn't doube the first one, I meant to put "full hydraulic" rather than factory
Date Posted: 14 Oct 2011 at 7:23am
Gary IN- Were located in Maine LOL.
Okay well we looked up some 14 & 17 buckets, he found one that is 60"(picture posted below) he wants to look at it but wants to make sure it will fit.
http://www.allischalmers.com/new/forum/uploads/5988/bucket.jpg - uploads/5988/bucket.jpg
This is the information from the listing:
Front end loader off my 1954 Ford Golden Jubilee NAA, will fit other utility tractors, worked good, not using it anymore. Step through frame,60" bucket probably from the 60s, ran on tractor hydraulics.
Once again thanks for the help and information guys!
Posted By: AC WD45
Date Posted: 14 Oct 2011 at 10:06am
If you have the 2-way hydrauics, it should work. That looks like a Paulson loader.
Date Posted: 14 Oct 2011 at 7:37pm
Unfortunatly that one was sold....so now we are on the hunt for another one.
