Print Page | Close Window
Model B Blade
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=34966
Printed Date: 01 Apr 2026 at 7:50am
Topic: Model B Blade
Posted By: shattercane
Subject: Model B Blade
Date Posted: 03 Aug 2011 at 4:57pm
Does anyone know if there was ever a belly mounted blade for a B or C? I've got my Dad's 3020 for snow removal now and would like to get the green paint off the farm if possible. If anyone has built one or has ideas on how to build one with a manual lift similar to the sickle mower I would be interested to see how it was done. Thanks in advance.
Posted By: Dusty MI
Date Posted: 03 Aug 2011 at 6:21pm
I have been thinking of making one for my G. I can get the blade and blade edge from my local Woods dealer. Thinking of mounting it on the cultivator frame.
Dusty
Posted By: Dakota Dave
Date Posted: 03 Aug 2011 at 6:37pm
I have built a couple. use the plow bracket for hinge points. the left arm has a swivel point at the blade. it works very nice for shapeing a road. since the blade is btween the axles instead of hanging out back  its very easy to smooth an area.
Posted By: beeman
Date Posted: 03 Aug 2011 at 6:44pm
We mounted  a blade on our  old B s cultivator  .Used the stock feet and bolted a section of used motorgrader cutting edge. It worked fair for smoothing the driveway after we added some weight to it. You can loosen one side and slide it back for some angle to cast material . Being mounted under the tractor you can see  the blade well .
1949 B   3930 Ford- Have owned other Orange ,green,red,yellow,dark green tractors and equipment.
Posted By: GlenninPA
Date Posted: 03 Aug 2011 at 7:49pm
+1 on using the cultivator frame.
I also saw a nice job at the Orange Spectacular a few years ago, but I can't locate the photo right now.
Good judgment comes from experience. Experience comes from bad judgment.
From listening comes wisdom and from speaking comes repentance.
Wise men learn more from fools than fools from the wise.
Posted By: Dwayne TX
Date Posted: 04 Aug 2011 at 9:53am
Got one, but I've never seen it mounted.  My Grandad said he used it to build a small stock tank and some terraces.
Posted By: RichinWis
Date Posted: 04 Aug 2011 at 1:33pm
I have some literature from the Meyers plow company showing plows on the B & C and also the G mounted to the master lift assembly, I would sure like to find one of those blades.
Posted By: MNLonnie
Date Posted: 04 Aug 2011 at 1:44pm
If you want to get crazy you could look for a Drott grader attatchment for it which makes it look like a Speed Patrol. There is one here locally mounted on a WD but most I have seen were on B's. I think Drott is the correct name?
