Print Page | Close Window
B questions sed. bowl & governor
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=34222
Printed Date: 08 Sep 2025 at 9:13pm
Topic: B questions sed. bowl & governor
Posted By: Mark in Iowa
Subject: B questions sed. bowl & governor
Date Posted: 20 Jul 2011 at 2:38pm
As always I appreciate all the help I get from you guys.
My B is running a little rough and without the rpms/power under a load it should have. The carb has been cleaned and rebuilt . New magneto.
When the tractor is running I am seeing air bubbles intermittently in the sediment bowl.
Is that an indicate of a plug/dirt in the gas line?
Is there a way to adjust the governor to increase the rpms/power? If so pictures would help.
          Thanks for the help, Mark
Posted By: CTuckerNWIL
Date Posted: 20 Jul 2011 at 4:20pm
Mark, I doubt the air bubbles would cause any problem, but I don't know that I have every seen the like.
 Setting a rebuilt carb needs to be done under load to get the best out of the engine. I don't know how it was set, but this could be part of the problem. What kind of shape is the rest of the engine? It could be low on compression if it hasn't been rebuilt lately. What shape are the valves.
Posted By: Gary in da UP
Date Posted: 20 Jul 2011 at 4:55pm
 Sometimes tractors that sit alot just need the snot worked out of them. Most every tractor I have bought in the last 15 years benifitted from exercise. Sticky rings & valves can  sometimes"heal" themselves with a few workouts, some tuneup parts and fresh fluids and filters. Don't try to go to the governor first without a tuneup and re-setting the valve lash.
Posted By: wkpoor
Date Posted: 20 Jul 2011 at 5:05pm
I would at least inspect the governor before I would do any adjusting. I have 8 CAs and one B. Plus some spare governors. Almost all have wear or are worn out. One even tried to get through its housing. And recently a forum member had a governor fly weight come off and lodge in the timing gears. Couldn't hurt to just inspect.
