Print Page | Close Window
Embarrassing G-engine question
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=31942
Printed Date: 16 Nov 2024 at 3:17pm
Topic: Embarrassing G-engine question
Posted By: G-Money
Subject: Embarrassing G-engine question
Date Posted: 08 Jun 2011 at 4:12pm
I'm putting new distributor, wires, plugs, etc,... and I know the firing order is 1-3-4-2, but what is the number one piston and so fourth on the engine.  Sorry to be so dumb on a small G engine.....but thanks for the help.   I have 3 manuals but none actually tell you what the number one piston is....
Posted By: DonDittmar
Date Posted: 08 Jun 2011 at 4:47pm
#1 should be opposite the clutch.  #4 would be directly next to the flywheel, with number 3 next, then #2, the#1 nest to the radiator
1968 D15D,1962 D19D
Posted By: jaybmiller
Date Posted: 08 Jun 2011 at 4:59pm
#1 is at the front of the engine(always ?) ,but since the engine is mounted 'backawards', it's the one nearest the rad/fan.
You're right 3 books here too, NO picture of who's first !!
Posted By: Dick L
Date Posted: 08 Jun 2011 at 6:33pm
Number one is at the crankshaft pulley. That would be to the rear of the tractor on a G.
To the right in the picture.
Posted By: CTuckerNWIL
Date Posted: 08 Jun 2011 at 6:35pm
Don and Jay are only partway right which could mess you up. The engine is in backwards. The number 1 cylinder is at the back of the tractor. The radiator and fan are  above the clutch and flywheel which is on the rear of the engine block next to number 4 cylinder. Now that should be clear as mud. Charlie
Posted By: JoeM(GA)
Date Posted: 08 Jun 2011 at 6:48pm
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Posted By: G-Money
Date Posted: 08 Jun 2011 at 7:30pm
Joe and Dick, thanks for showing this issue in the picture form....pictures are always good for us Gump types.....even then, some of the explanations above still seemed confusing......now to set the wires on the distrib.......
Posted By: Fred in Pa
Date Posted: 08 Jun 2011 at 9:56pm
There are some engines that # 1 is at the flywheel end of engine ,remeber the company that bought out AC in 1985
Posted By: Dave Everett
Date Posted: 09 Jun 2011 at 4:36am
YES FRED>>>>>>>> and they built GREEN tractors as well   !!!!
Posted By: John (C-IL)
Date Posted: 09 Jun 2011 at 7:51am
And if you think about it for a while it doesn't matter which cylinder you call number one, the end result is the same. 1-2-4-3 from the radiator back becomes 4-3-1-2 from the clutch forward. So if you look at those numbers you can see that the firing order doesn't change. The only thing that is important is that when it is time for a given cylinder to fire the rotor is supplying spark to THAT cylinder.
Posted By: Dick L
Date Posted: 09 Jun 2011 at 8:37am
True but it can become very confusing when you do not have the principals rock solid in your head. A person need not know the firing order in advance if they know how an engine operates. One only has to check for the compression strokes and watch the valves close and mark it down.  You could then call any one of the plugs number one but would not have a standard reference point to discuss problems with others.
Date Posted: 09 Jun 2011 at 10:01am
My point exactly Dick, I could have worded it better.
Posted By: allis g
Date Posted: 02 Oct 2012 at 12:21pm
what position is number 1 on the distributer?
Posted By: JoeM(GA)
Date Posted: 02 Oct 2012 at 6:41pm
on mine it is here, the tech manual steps are attached also
Ford 345C TLB
Date Posted: 02 Oct 2012 at 7:53pm
Which ever one the rotor is pointing to when number 1 is at TDC of the compression stroke. It can be any of the 4 holes, depending on how the distributor was installed.
Date Posted: 03 Oct 2012 at 7:54am
My Bad......I forgot the engine is backwards in the G. Sorry for the confusion.....
1968 D15D,1962 D19D
Posted By: jdobbins
Date Posted: 07 Sep 2017 at 2:34pm
My cows pulled the wires off the distributor of my G. Can some one pls show me how to put them back in the right order on the distributor cap.
Posted By: Dusty MI
Date Posted: 07 Sep 2017 at 6:24pm
Turn the engine over until #1 piston is at the top of it's compression stroke. Then the post that rotor is pointing to is #1.
Dusty
Posted By: jdobbins
Date Posted: 08 Sep 2017 at 1:04pm
Dusty. Thank you. Got it running again
