Print Page | Close Window
anuther WD update, cornpicker parts needed
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=30142
Printed Date: 05 Mar 2025 at 10:23pm
Topic: anuther WD update, cornpicker parts needed
Posted By: Don(MI)
Subject: anuther WD update, cornpicker parts needed
Date Posted: 02 May 2011 at 8:39pm
Got the undercarriage bolted on the tractor tonight, looks good to see it under there.
I am in need of parts though, seems like I am missing a couple brackets.
I need 2 bell crank link brackets shown in the picture below, and also the (LH Ram bracket) that holds the LH cylinder up in place. I also am in need of the (RH Ram Support) cylinder bracket. It is different from the standard, its a lower bracket, and is flipped in reverse of normal (see picture). If anyone has these parts please shoot me an email, If I can't find em in the next couple days I will make some out of flat stock.
Thanks! Don
Posted By: Don(MI)
Date Posted: 03 May 2011 at 11:19am
Anyone have the brackets kickin around?
Posted By: R Aiken
Date Posted: 03 May 2011 at 1:43pm
I have some extra parts, that I got at Dales last summer, for sale.  Richard
Posted By: Don(MI)
Date Posted: 03 May 2011 at 3:06pm
pm sent, I need the two small brackets in the center top area of the picture, with the c shaped holes in them, also the one with the other flat steel bracket bolted to it.
Also the flat stock steel piece with 2 studs on it (center lower part of picture). 3 pieces total
Posted By: R Aiken
Date Posted: 03 May 2011 at 3:23pm
sent you a PM
