Print Page | Close Window
where can i get liner o-rings for a model c
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=28552
Printed Date: 01 Mar 2025 at 10:03am
Topic: where can i get liner o-rings for a model c
Posted By: jb from md
Subject: where can i get liner o-rings for a model c
Date Posted: 04 Apr 2011 at 7:45pm
i need a complete set of liner o-rings for my 1941 c.. cant seem to be able to find them... also need a gasket kit, any help would be great. i want to get this thing going thanks alot ...Jb
8050 FWA, 190XT, 185, Styled wc, Unstyled wc, (2)C, (2)WD45NF, WD45WF, WD,416h, 716h, 312h, 8070 pedal.
Posted By: norm[ind]
Date Posted: 04 Apr 2011 at 7:52pm
  WE HAVE THE ORIG. ORING FROM A-C  should have the size when ordering    1-800-254-3116  if you have orig a-c sleeves
Date Posted: 04 Apr 2011 at 8:02pm
it doesnt have the original sleeves in it it was overhauled and must have rolled an oring it got water in the oil on start up and the block and head was checked before assembly so it must be in the liner orings  or head gasket either way i want to go back through it and get it back together...Jb
Posted By: Chalmersbob
Date Posted: 04 Apr 2011 at 9:04pm
did you check the soft plugs in the head? (core plugs) Bob
Date Posted: 05 Apr 2011 at 6:48am
no i didnt, i never thought of it..i bought the tractor in pieces ,the old owner said the block cracked so he went and picked up a bare block, thats why its been overhauled.the head is the original head and didnt get water in the oil before, it leaked water out the side of the block (i guess it froze),but still ran before he tore it down, is it common to have bad freeze plugs in the head?? i thought i'd start over and do it  myself this time, i have rebuilt a few wd's and never had a problem and am still working them...thanks Jb
Posted By: Fred in Pa
Date Posted: 05 Apr 2011 at 7:26am
Pull oil pan ,see where anti . is coming from ,inside sleeve around piston,outside sleeve or coming down with retrun oil from top end. If motor was rebuilt and the head was done freeze plugs should have been replace.Pull valve cover and check that before pulling pan.
Date Posted: 05 Apr 2011 at 7:28am
Check sleeve height and check block deck
