tire sealant pump
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=194352
Printed Date: 26 Sep 2025 at 8:05pm Software Version: Web Wiz Forums 11.10 - http://www.webwizforums.com
Topic: tire sealant pump
Posted By: edmo
Subject: tire sealant pump
Date Posted: 31 Mar 2023 at 3:15pm
Going to put some sealer from a 5-gallon container in some tractor tires. I thought the pump advertised along side the sealer for as much as the sealer was a lot of money for likely a one time use. I have all manner of compressors, shop, small 12V, and a couple of old hand bicycle tire pumps. Anybody out there have a macGuyver or other alternative than the $100-$260 alternative. Yeah, I'm cheap.
Posted By: steve(ill)
Date Posted: 31 Mar 2023 at 3:44pm
how about a quart bottle like gear lube comes in... 3 inches round and several inches tall... connect a 3/8 inch hose and slip the hose over the tire valve and SQUEEZE. Tire should be no air to start with.
------------- Like them all, but love the "B"s.
Date Posted: 31 Mar 2023 at 3:50pm
or buy one of these and you get the pump and an extra gallon..
Posted By: edmo
Date Posted: 31 Mar 2023 at 3:51pm
forgot to mention back tires may need about 2-3 liters each. The squeeze bottle would work and probably be fitting for me being cheap, but i don't have PopEye forearms
Posted By: edmo
Date Posted: 31 Mar 2023 at 3:55pm
I haven't had much luck with the green slime and have some gemplers extreme on the way way. Their pump price was 260+ shipping.
Posted By: Allis dave
Date Posted: 31 Mar 2023 at 4:17pm
Can I make the hard suggesiton here? Don't use sealant. Tear the tire down and fix it right. Sealant just makes it a mess for the next guy
Posted By: edmo
Date Posted: 31 Mar 2023 at 5:11pm
Appeciate that, but am working a piece of property with a lot of young locust trees, IM in the process of evicting their parents, pulling the Youngsters hydraulically if I can and tordoning the ones I cant. I've paid more than enough in tire/tube repair to pay for all the sealant I need. If there is a better way that works I'm all in. And the future owner is my son, so i'm going to sneak it past him.
Posted By: Dennis J OPKs
Date Posted: 31 Mar 2023 at 5:24pm
Once you put that stuff in a tire you'll probably never clean it up & your tire is trashed. No one wants to work with that stuff, it's a one time deal. Ask me how I know.
Posted By: DiyDave
Date Posted: 31 Mar 2023 at 5:26pm
https://www.harborfreight.com/search?q=suction%20gun" rel="nofollow - https://www.harborfreight.com/search?q=suction%20gun
------------- Source: Babylon Bee. Sponsored by BRAWNDO, its got what you need!
Posted By: den/southern illinoi
Date Posted: 31 Mar 2023 at 6:03pm
See if you can find or borrow a set of steel wheels like the amish use. That's what a local guy did. Once he got hid of the thorns, he got rid of the steel wheels. Den
------------- Own 4 wheel 20, 2-5015, 5020 and associated equipment and 2 electric forklifts.
Posted By: 200Tom1
Date Posted: 31 Mar 2023 at 9:28pm
Dennis you are right. The dam stuff gets between the tire and tubes. It creates one heck of a mess for us guys that still work on tires. There's only 1 thing I know that is worse, that is condensed milk. Ya years ago we had guys putting that stuff in their tires. It gets rotten and stinks so bad a stray dog won't roll in it. But it his outfit, it might work for him. Once in a while it does.
Posted By: DSeries4
Date Posted: 01 Apr 2023 at 9:00am
Buy a cheap bulldozer to use for your cleanup and then sell it for the same price you bought it for. No more tire problems and you save wear and tear on your tractor.
------------- '49 G, '54 WD45, '55 CA, '56 WD45D, '57 WD45, '58 D14, '59 D14, '60 D14, '63 D15D, '66 D15II, '66 D21II, '67 D17IV, '67 D17IVD, '67 190XTD, '73 620, '76 185, '77 175, '84 8030, '85 6080
Posted By: LYNNMN
Date Posted: 01 Apr 2023 at 9:57am
or find foam filled tires
Posted By: Dakota Dave
Date Posted: 01 Apr 2023 at 10:28am
https://www.walmart.com/ip/BR-Tools-AS6P-6-gal-Pail-Tire-Sealant-Pump/709929986?wmlspartner=wlpa&selectedSellerId=1148&adid=22222222222110636079&wmlspartner=wmtlabs&wl0=e&wl1=o&wl2=c&wl3=74835604587585&wl4=pla-4578435162485094&wl5=&wl6=&wl7=&wl10=Walmart&wl11=Online&wl12=709929986_10000001205&wl14=tire%20sealant%20pump&veh=sem&gclid=ae9609345786176d08266d1c1bc08c9c&gclsrc=3p.ds&msclkid=ae9609345786176d08266d1c1bc08c9c" rel="nofollow - BR Tools AS6P 6 gal Pail Tire Sealant Pump - Walmart.com appears you could buy the pump for $34. our you could try to rig something else up that'll probably blow up and shoot expensive sticky goop everywhere. the sealant pumps dosen't use air it pumps fluid only.
Posted By: edmo
Date Posted: 01 Apr 2023 at 12:29pm
Thanks for the suggestions. Think I'll go with the hand operated version. Need the exercise anyway. I've been using my D-15 on that piece of property for brush cutting, disking, etc, and have had numerous flats and a few tube replacements. I've spent a bunch for tracked skid steer work with tree puller and grapple.
I've often thought of the dozer idea, but don't know enough about them to keep from buying junk.
i'll be using the sealer stuff on a little newer non-orange tractor with tubeless tires so am guessing that any holes the sealer wont fix will have to be plugged anyway.
Date Posted: 01 Apr 2023 at 1:03pm
edmo.. i have done exactly what your talking about.... its a cheap fix instead of multiple flats.... you can worry about the goo and crud later, if ever..... Should work for you.
Posted By: MACK
Date Posted: 01 Apr 2023 at 8:44pm
When I bought my dozer a guy told me (if you don't want to work on one don't buy one) He was correct. MACK
Posted By: SteveM C/IL
Date Posted: 01 Apr 2023 at 11:13pm
There are places which rent dozers. Not cheap but less than hiring the guy who owns one. You do need to know how to operate one. More to it than meets the eye.
