Down shifting when you step in the clutch
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=190869
Printed Date: 07 May 2024 at 4:31am Software Version: Web Wiz Forums 11.10 - http://www.webwizforums.com
Topic: Down shifting when you step in the clutch
Posted By: tthams
Subject: Down shifting when you step in the clutch
Date Posted: 24 Sep 2022 at 7:29pm
I was just wondering if anyone could tell me when a powershift transmission on an Allis 7060 should downshift to 4th gear from 5th or 6th gear?
Is it when you first get to the inching spool zone when pressing in the clutch pedal, or when it's close to being fully depressed on the floor?
Posted By: DrAllis
Date Posted: 24 Sep 2022 at 7:37pm
If the linkage is properly adjusted, it will hit 4th gear just BEFORE you get into the brake zone. When you depress the pedal to the floor, the lever will wiggle a little as it is trying to go farther than 4th but it cannot.
Posted By: tthams
Date Posted: 24 Sep 2022 at 8:31pm
Thank you. I was wondering if something was off in the transmission. In gears 1-3 the tractors starts coasting to a stop when I hit the inching zone and start to apply the brakes.
In gears 4-6 I have to almost get to the brake zone before it downshifts, and I can stop the tractor with a gradual pressing of the brakes.
But it sounds like it's normal in that range to do that.
Posted By: MACK
Date Posted: 24 Sep 2022 at 8:45pm
Swing battery box out and look at valve body. There is a cam on linkage that pushes on lever out of valve. That is what moves it back to 4th. MACK
Posted By: Jack(Ky)
Date Posted: 28 Sep 2022 at 7:38am
I push my pedal down a little and drops to fifth push a little further and drops to fourth. Handy and it's that way to keep you from ruining fifth and sixth.
------------- '59 D14 '68 170 Diesel '81 7020 40 All Crop
Posted By: DrAllis
Date Posted: 28 Sep 2022 at 8:18am
That kick-down feature had to be there !! Disconnect it sometime and you'll soon find out the tractor will not stop when the inching pedal is depressed when in 5th or 6th !!!
Posted By: 55allis
Date Posted: 28 Sep 2022 at 12:24pm
Also it is nice because when you come up to a stop sign and clutch it will go back so you won’t burn the clutch out...
