Print Page | Close Window
model A at auction
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=19080
Printed Date: 07 Feb 2025 at 6:03pm
Topic: model A at auction
Posted By: lewis_tudor
Subject: model A at auction
Date Posted: 04 Oct 2010 at 4:22pm
there was an auction up my way near Petworth, Surrey, UK and there were a few different tractors for sale including a Field Marshall 3A that made £14,000 and a done up Allis Chalmers Model A. it looked very nice and straight. it drove really smoothly but had the wrong top tank on the rad (it had a 20-35 one) with an inch and abit spacer under it lol and it had a made up manifold that actually looked quite convincing. also the engine oil was milky.....are these engines known for that????
anyway it did not sell. £20,000 he called then £15k and then dropped to £10k but no one bid and he did not go any lower.....so the buyers were just not there
just thought id let you all know
regards
Lewis
Posted By: everett048
Date Posted: 05 Oct 2010 at 1:50am
Hi Lewis that A was imported from Canada a few years ago by Stan Kick it was restored by Peter Nugent who couldnt find the correct header tank for it he also made the manifold for it,Peter sold  it to  Metcalf  steam valves  for 16000  it had a cracking paint job and new tyres all round i have since seen the wheels on my mates A but didnt know what happened to the tractor as for milky oil its more than likely its the sleeve seals leaking,Peter never ran it for long as he said the home made manifold used to ice up.
Posted By: Tricky Dickie
Date Posted: 05 Oct 2010 at 5:00am
Yes, that's right! I also know that A and it is an imported petrol model which has a number of incorrect features and faults, masked by an excellent paint job.  I looked at it some years ago and noticed the water in the oil at that time, but did not point it out to the owner, as he is a very nice guy - I just declined to bid on the tractor. Certainly I would not have offerred anything near to the (in my opinion recklessly unrealistic) £16k price at which it changed hands some years ago and I suspect that it will have lost a pile of money for someone when it eventually finds a new home.
Tricky Dickie
Date Posted: 05 Oct 2010 at 6:08am
hello guys! ah didnt realise it was one of Stan's i know him well
okay tell me more about the sleeve seals??? lol
so do you think it was Metcalf who was selling it? the fella who was starting and driving it also had other more modern tractors for sale there
Lewis
Date Posted: 05 Oct 2010 at 8:03am
Lewis, When I looked at it, the A belonged to Peter Nugent before he got that irresistable (and crazy) £16k offer. I have since seen it in a couple of sales, now fitted with different rear wheels and looking a little "tired" but it never gets near to being sold. I heard that Peter had eventually taken it back for a much lower price, but that was only idle gossip and I really do not know who owns it now. There are much better A's around and I can wait.
Tricky Dickie
Date Posted: 05 Oct 2010 at 4:01pm
fair enough Richard!
could anyone tell me more about the sleeve seals? are they at the bottom of the bore or in the water jacket i have no idea? is it repairable?
Lewis
Date Posted: 05 Oct 2010 at 4:24pm
Hi Lewis they are simple remove heads pistons pull sleeves clean up block fit new o rings to sleeves and refit,the wheels off of that tractor are on Will Wood wards A
both A,S where owned by metcalf steam valves before he passed away he made 1 correct A out of 2 i was told this by his son Richard at the Dorset steam fair i was introduced by Will Woodward to him, the A that will has with the black wheels used to belong to Richards father .
Date Posted: 05 Oct 2010 at 4:46pm
okay thanks Mark or is this Dave lol? i take it they are huge O rings and Norm sells them?
is this quite a common thing to go wrong then?
i see, sorry but i never got the man's name who was selling it :S
Lewis
Date Posted: 05 Oct 2010 at 5:05pm
Lewis yes Norm sells them, normally if a wet block leaks it is the o rings unless sleeves r cracked.
Date Posted: 07 Oct 2010 at 4:15am
I realise that this will horrify the purist engineers here, but I have in the past, successfully used K-Seal on a Case 500 with leaking liner seals. That was 10 years ago and I sold the tractor some time back, but recently saw it and checked the oil - perfectly black and clear of any water contamination! It's worth a try if the engine is otherwise good and the water leak past the seals is only slight. If it does not do the trick, then obviously the liners have to be pulled and the O-rings replaced, but in my view that is best done as part of a full rebuild.
Tricky Dickie
