Print Page | Close Window
6 volt wiring w/generator
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=171086
Printed Date: 05 Apr 2026 at 12:14pm
Topic: 6 volt wiring w/generator
Posted By: snowman(MI)
Subject: 6 volt wiring w/generator
Date Posted: 13 May 2020 at 11:31am
Guys, this is probably a simple one but I need some help.  I didn't take it apart but was called on after the fact.  See my picture and question
1950 WD, 1966 D-10 III, 1961 D-10 II, 1966 D-15 II Gas, A-C Minibike, 917 Hydro Mower, 917 Hydro Blower w/cab, West Michigan "Allis Express"
Posted By: jaybmiller
Date Posted: 13 May 2020 at 3:38pm
The new cutout switch is probably a big DIODE so...
if you have a +ve ground, as in the diagram, then the 'A' terminal of the genny goes to the ' + ' stud of the 'cutout'. The unmarked stud goes to the big wire...to ammeter.
Think of the diode as a one way switch. it allows power (current) to only flow one way.
The 'F' terminal of genny goes to the smaller wire that goes to the 'light switch' that controls the Field current ( charge rate).
Date Posted: 16 May 2020 at 7:11pm
Thank you for the advice, generator needs rebuild
