Print Page | Close Window
Trans brake on maroon 7000
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=170956
Printed Date: 09 Oct 2025 at 3:16pm
Topic: Trans brake on maroon 7000
Posted By: Tim NH
Subject: Trans brake on maroon 7000
Date Posted: 09 May 2020 at 9:27am
I have the hardest time going from park to say third. I may have to push clutch in 3 or more times before it will go in. In the picture, is this the lever to adjust it. I can't seem to find that adjustment in the manual.
 Tim
Posted By: DIESEL
Date Posted: 09 May 2020 at 11:40am
I'm pretty sure all maroon bellies have a dry clutch, so no trans brake. Trans brake came with black belly and t-handle shifter. That's on a 7000.
Posted By: Lynn Marshall
Date Posted: 09 May 2020 at 12:34pm
All the maroon belly 7000 tractors did use a dry clutch, but they also have a transmission brake and an adjustment rod like what is shown in that picture. I don't remember the compressed length of the spring,but that is where you adjust it. I have had to replace the brake puck on some tractors.
Posted By: Tim NH
Date Posted: 09 May 2020 at 4:46pm
Lynn, I was told maybe it has been set to tight not allowing it roll to a stop, for engagement. So I will back the nuts off a little and try it.
Posted By: DougG
Date Posted: 09 May 2020 at 5:42pm
The dry clutch has nothing to do with the trans brake - im pretty sure it works off the clutch pedal and is activated at the last inch of travel on the clutch pedal
Posted By: Ron(AB)
Date Posted: 09 May 2020 at 7:07pm
Hard shifting into a gear is common with wear...1st and 3rd gear primarily.
Reverse always was touchy from new. It like to grind to find...a wee bit anyway.
My theory is worn shifter forks. I say "theory" is because I haven't check mine to verify, but mine does that too.
It all depends on how much use on the tractor and how much gear shifting has it done?
Posted By: Tim NH
Date Posted: 28 May 2020 at 7:00pm
I finally had a chance today to work on the shifting issue. I did loosen the trans brake a bit, 1/8". So long story short. I have never driven a tractor w/ a clutch brake. And have found the right way to operate it now. I did adjust the trans brake back to where I found it.
  Tim
Posted By: DougG
Date Posted: 28 May 2020 at 7:28pm
Glad you figured it out !
