Print Page | Close Window
D-17 or 170 with Left Hand Power Director Lever
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=170501
Printed Date: 04 Apr 2026 at 4:20am
Topic: D-17 or 170 with Left Hand Power Director Lever
Posted By: Bret (OH)
Subject: D-17 or 170 with Left Hand Power Director Lever
Date Posted: 24 Apr 2020 at 11:58am
I am installing a Left Hand Shuttle Clutch Lever on my 170 and I am looking for a photo of the bracket that holds the lever quadrant when lever is mounted on the left side.  I have had no luck finding the bracket for sale anywhere so I will build one, but it would be helpful to see how Allis did it.
Thanks in advance.  Bret (OH)
Posted By: Gatz in NE
Date Posted: 24 Apr 2020 at 12:55pm
Don't know if this will help, but here's a diagram from the AGCO Parts Books.
(enter as Guest, at prompt enter D17, click on D17 Tractor (Prior to Series IV, page 246)
Shows the Right-Hand version and Left-Hand version of the PD.
Note that the view for the RH version is looking FORWARD from operator's position;
the LH version is looking AFT
BTW, Item 3 for the LH version is not the same part as Item 3 (70237176) for the RH version
Date Posted: 27 Apr 2020 at 5:45am
Here is my solution to the Left Hand Lever.  I built a bracket of my own design using the quadrant and rear stop from the right side lever setup.  I modified the lever shaft by adding new keyways for the clutch fork and moving the oring groves and snap ring locations sideways by .395 thousandths. This set the lever to the left enough to get the fabricated bracket behind it.  I also had to modify the clutch pedal with the offset so there would be no interferance with the lever.  Allis made a special clutch pedal for this application but that also has been impossible to locate.
Posted By: m16ty
Date Posted: 27 Apr 2020 at 5:58am
This is the first I’ve heard of the left-hand option. What was the reasoning behind it? Somebody with a disability on their right side?
Posted By: Pat the Plumber CIL
Date Posted: 27 Apr 2020 at 7:20am
Shuttle clutch option . loose 4 forward gears but now 4 forward and 4 reverse controlled by shuttle clutch . Usually mounted on left side.
Posted By: TramwayGuy
Date Posted: 27 Apr 2020 at 7:24am
Note: shuttle clutch option changes the PTO speed to a non-standard RPM.
Date Posted: 27 Apr 2020 at 7:33am
The reasoning was that your right hand would be very busy with the loader controls, the throttle, and although not very often, the transmission gear shift. While your left hand/arm is doing zilch.
Imagine having the PD lever still on the right side.
Posted By: mruhlig77
Date Posted: 27 Apr 2020 at 8:21am
Might be handy....what about H-3 dozer parts...same same??
Date Posted: 27 Apr 2020 at 10:20am
H3 is based on a D-15, same principal but most parts are different.
The One-Seventy I converted is still a Power Director, but as Gatz stated, I changed it so I could use the hand clutch with Left hand and hyd. with the Right.
Eventually, if I can find all the parts I will build a torque housing with all the shuttle gears and switch it into the One-Seventy.
The 170's from the factory had a 2 speed PTO, which made it useable at normal speeds but for me it doesn't matter as I don't use the PTO on this tractor for anything.
Posted By: Mapleshade
Date Posted: 27 Apr 2020 at 12:55pm
Nice looking 170. How about more photos?
Date Posted: 27 Apr 2020 at 6:59pm
@Bret(OH), Is that lever an actual left side reversing lever meant for shuttle ?
Good job on making the offset clutch pedal...looks factory
Nice One-Seventy btw
Posted By: dpower
Date Posted: 30 Apr 2020 at 7:17am
The factory cluth pedal for a 170 shuttle is wider, i think we may have an extra one not sure if dad wants to sell it or not.  We have a factory 175 and 170 shuttle clutch. Very fun to operate and would make an awesome loader tractor.
Posted By: Sugarmaker
Date Posted: 30 Apr 2020 at 10:41am
I agree! We need many more pictures If Bert is getting down to .395 thousandths he is doing some detailed work! And by the teaser pictures it sure looks good!
Date Posted: 01 May 2020 at 6:49am
I am (1) gear away from having all the parts necessary to build a Shuttle Shift torque housing for the One-Seventy, but it seems that I may never achive my goal, as that one gear seems as elusive to me as a Unicorn's Wisdom Tooth.
The gear I need is the Hollow Shaft Gear coming forward from the Transmission Clutch, Part # 70236549.  I believe it is almost exactly the same as a Power Director gear except that the Helix of the Teeth for the Shuttle is a mirror image of the Power Director.  Many salvage parts outlets show this part # in inventory but all so far have been mis-numbered in their inventory and are in fact Power Director gears.
This gear, as far as I know, is used only in the D-17, D-19, 170 and 175.  Seems that most of the Shuttle tractors are ones based on the D-15 driveline, and this gear is different in them.
If anyone knows where I could look for or find this gear I would appriciate the information.
I would be interested in that clutch pedal if it were for sale.  My modification works, but I would like to have an OEM pedal.
Date Posted: 01 May 2020 at 7:32am
Bret,
 Great looking Allis and Loader! I wish you the best to get the gear you need. Someone on this forum may have the part you need.
