Parts Question
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=168865
Printed Date: 09 May 2024 at 7:49pm Software Version: Web Wiz Forums 11.10 - http://www.webwizforums.com
Topic: Parts Question
Posted By: DMiller
Subject: Parts Question
Date Posted: 05 Mar 2020 at 5:18pm
My 180 is needing a refresh. Probably need to split the old girl, do a full major overhaul as have NO CLUE how long it has been IF has ever been overhauled. Lots of blowby, harder to start in cool weather but pulls strong.
Main question is from where to buy parts when get it down and inspected. Will mic the crank and check the bearings in it for std or under, sleeves, pistons rings cam bearings possibly oil pump and may be looking for advice on getting head inspected/valves done. Capital Diesel will be getting the nozzles to go thru, pump is less than four years on duty.
Posted By: WF owner
Date Posted: 06 Mar 2020 at 7:55am
There are several vendors, that support this forum, that sell quality parts at a reasonable cost, plus technical advice, if you run into a problem.
Jim Danforth at OK Tractor is the first that comes to mind.
Posted By: victoryallis
Date Posted: 06 Mar 2020 at 11:17am
I had bad luck with Reliance brand parts.
------------- 8030 and 8050MFWD, 7580, 3 6080's, 160, 7060, 175, heirloom D17, Deere 8760
Posted By: WF owner
Date Posted: 06 Mar 2020 at 11:23am
I have used Reliance parts for years and not one problem yet.
Posted By: DrAllis
Date Posted: 06 Mar 2020 at 11:26am
Figure on new exhaust seats (hard seats) new intake and exhaust valves and all new valve guides, resurface the head and do all this after it passes a magnaflux crack test.
Date Posted: 06 Mar 2020 at 11:57am
Mechanic with 35-40 years experience did my 8050 it made it 3 hours after overhaul and blew its head gasket. Put a Agco head gasket in and he noticed the Agco looked noticeably better. Read on another forum of same story.
Posted By: HD6GTOM
Date Posted: 06 Mar 2020 at 2:57pm
Sandy Lake has been good to me.
Posted By: SteveM C/IL
Date Posted: 06 Mar 2020 at 9:15pm
Well,parts and a head gasket do not go in the same catagory to me. When you said trouble with parts I thought you meant cracked piston or sleeve or valve issues. Hard parts was my concern.
Posted By: DMiller
Date Posted: 07 Mar 2020 at 5:49am
As noted in the comments decided to call our local AGCO dealer, he has access to many parted out old Allis 301s if need hard parts, uses a local machine shop for head work with good results, and can supply AGCO basic rebuild kit out for around $1200 +/- dependent of bearings and he can get std/.010/.015s, cam bushings and aftermarket cams are available. He also has nozzle rebuild service equipment in house so guess will be going down that road when done with the 7G,
