D 15 seat pins
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=168409
Printed Date: 06 Jun 2024 at 1:09pm Software Version: Web Wiz Forums 11.10 - http://www.webwizforums.com
Topic: D 15 seat pins
Posted By: ACinSC
Subject: D 15 seat pins
Date Posted: 17 Feb 2020 at 3:10pm
Wondering if anyone has replaced these pins/rods ? Have one that is very rusty with lots of play . Will a 1/2" steel rod cut to size work ? Thanks
Posted By: Joe(TX)
Date Posted: 17 Feb 2020 at 3:17pm
That's what I used on my 190 seat. Just have to drill holes for the roll pins.
------------- 1970 190XT, 1973 200, 1962 D-19 Diesel, 1979 7010, 1957 WD45, 1950 WD, 1961 D17, Speed Patrol, D14, All crop 66 big bin, 180 diesel, 1970 170 diesel, FP80 forklift. Gleaner A
Posted By: ACinSC
Date Posted: 17 Feb 2020 at 3:32pm
Roll pins ?? Good to know . Hafta get my magnifying glass out . Thanks
Posted By: bleeds orange
Date Posted: 17 Feb 2020 at 3:43pm
I just did all the pins and bushings on my d15 seat. Pretty much torch everything out.
Bought new shock also.
Got everything I needed at DJS tractor. Yes there is roll ins in each rod . New rods come pre drilled.
Thanks cory
Posted By: ACinSC
Date Posted: 17 Feb 2020 at 4:20pm
Thanks Cory . If only I had a torch . I've seen those in the catolog . Only have one that's really bad . Beginning to think it's going to stay wobbly .
Posted By: Burl
Date Posted: 17 Feb 2020 at 4:59pm
I always just cut them into with metal blade on reciper. saw. Cut on both side then drive out rest of pin from seat plate. Goes quick !! Cut new pin from cold roll and replace . Most of the time I used cotter pins instead of roll pins. Have not had one fail yet.
Posted By: ACinSC
Date Posted: 17 Feb 2020 at 6:39pm
Thanks Burl . Sounds doable .
Posted By: DSeries4
Date Posted: 17 Feb 2020 at 6:59pm
Lots of heat, penetrating oil and hammering. I have done it on several of my seats already. I get my local fab shop to put new bushings in and make new pins out of stainless so they do not rust.
It's the best thing you can do to improve the ride on these old seats. Day and night difference. It is a bit of work, but you will notice the difference.
------------- '49 G, '54 WD45, '55 CA, '56 WD45D, '57 WD45, '58 D14, '59 D14, '60 D14, '61 D15D, '66 D15II, '66 D21II, '67 D17IV, '67 D17IVD, '67 190XTD, '73 620, '76 185, '77 175, '84 8030, '85 6080
Posted By: ACinSC
Date Posted: 17 Feb 2020 at 7:40pm
Thanks Myron I've been hitting this rusty pin with kroil for a good while . Gonna see if I can find a piece of 1/2" steel tomorrow
Posted By: DSeries4
Date Posted: 17 Feb 2020 at 7:41pm
Make sure you have all the roll pins removed first.
Posted By: ACinSC
Date Posted: 17 Feb 2020 at 7:45pm
I can only see one . Guess there's two ? Anyone remember the size ? Thanks
Posted By: Mikez
Date Posted: 17 Feb 2020 at 8:32pm
I did the seat in our 200 and bought all parts through agco
Posted By: DiyDave
Date Posted: 17 Feb 2020 at 9:03pm
IIRR, there's only 1 in the center...
Comes out better if you have the appropriate roll pin punch...
------------- Source: Babylon Bee. Sponsored by BRAWNDO, its got what you need!
Posted By: ACinSC
Date Posted: 18 Feb 2020 at 4:47am
I have a roll pin punch set . This pin's very rusty but I think I see a roll pin on the right . Thanks guys
Posted By: DrAllis
Date Posted: 18 Feb 2020 at 7:23am
Lay the seat frame on its side and drive the 1/2" pin downwards with a short fat punch and a 4 lb hammer. Doing it this way will shear off the roll pin so you don't have to remove it. Do this with the roll pin down. The seat frame has to be supported against something solid when you start hammering against the pivot pin.
Posted By: ACinSC
Date Posted: 18 Feb 2020 at 11:20am
Posted By: DrAllis
Date Posted: 18 Feb 2020 at 11:57am
I guess I sometimes use a deep socket to lay the seat frame against, using the socket as a die to drive the pin into making it solid when you hammer away.
Posted By: ACinSC
Date Posted: 18 Feb 2020 at 12:20pm
Posted By: Gary
Date Posted: 18 Feb 2020 at 3:23pm
Kit provided by a Forum Member / Supplier
https://www.ebay.com/itm/Allis-Chalmers-5-Piece-Seat-Pin-Replacement-Kit-D10-D12-D14-D15-D17-D19-D21-19/283069241977?hash=item41e83dda79:g:jdsAAOSwP9Jb0yBs" rel="nofollow - https://www.ebay.com/itm/Allis-Chalmers-5-Piece-Seat-Pin-Replacement-Kit-D10-D12-D14-D15-D17-D19-D21-19/283069241977?hash=item41e83dda79:g:jdsAAOSwP9Jb0yBs
Posted By: ACinSC
Date Posted: 18 Feb 2020 at 4:13pm
Thanks Gary but I only need one of the longer ones . Rest look like they have been replaced. Hopefully I can buy some 1/2" rod somewhere .
Posted By: Lon(MN)
Date Posted: 19 Feb 2020 at 7:12am
I did my 190, D14, D17 and D19. Bought all the parts from Agco. Just a punch and hammer to get it apart.
Posted By: ACinSC
Date Posted: 19 Feb 2020 at 7:41am
Thanks Lon . With all the rain we're having today may be a good day for some hammer time .
Posted By: ACinSC
Date Posted: 20 Feb 2020 at 4:18pm
Started on the rusty seat pin removal today . Looks to me that if you want to replace the shock you have to pull a couple lower pins ? Sound right ? Thanks
Posted By: ACinSC
Date Posted: 03 Mar 2020 at 1:45pm
Finally finished my seat rebuild . Replaced the shock and all the pins but one . Also replaced 4 bushings . Much better . Hopefully my favorite son will post a pic . Thanks
Posted By: WeisAC2
Date Posted: 03 Mar 2020 at 1:49pm
Posted By: ACinSC
Date Posted: 04 Mar 2020 at 6:30am
Thanks to my son for posting the pics and to all the advice I received here. Now I'm ready for some seat time .
