Wheel Weight
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=167503
Printed Date: 28 Apr 2024 at 12:38am Software Version: Web Wiz Forums 11.10 - http://www.webwizforums.com
Topic: Wheel Weight
Posted By: PDehring
Subject: Wheel Weight
Date Posted: 17 Jan 2020 at 6:42pm
I found a set of weights that have a casting number of 254134-2 and have BW cast into them as well. Anyone know what they fit?
Yes, I looked on the weight page on here.
------------- 1937 M Crawler, 1963 D21, 1964 D21, 1965 D12 SIII, 1970 220, 1976 185
Posted By: jaybmiller
Date Posted: 18 Jan 2020 at 6:09am
I'm thinkin maybe a picture or size/shape might help jog the grey cells here.Ballpark weight ? Qty per wheel ? All I know about weights is you MUST check the nuts/bolts every so often as any loosey goosey and the rim will be ,um, compromised.....
------------- 3 D-14s,A-C forklift, B-112 Kubota BX23S lil' TOOT( The Other Orange Tractor)
Posted By: Gary
Date Posted: 18 Jan 2020 at 1:13pm
Link to 'that other' web site:
https://www.yesterdaystractors.com/cgi-bin/viewit.cgi?bd=ttalk&th=1962949" rel="nofollow - https://www.yesterdaystractors.com/cgi-bin/viewit.cgi?bd=ttalk&th=1962949
Posted By: KJCHRIS
Date Posted: 18 Jan 2020 at 1:22pm
Not much to go on? # of bolt holes, distance center to center on opposing holes, inside diameter, outside diameter, thickness, approximate weight and of course pictures if possible would help. Your number is very close to weights I have on a late AC200 and early 7000 tractors. They have weights with; BW 254136-2 on them, yours likely were made about the same time. They have 6 mount holes, 1.75" to 2" thick, 24" OD, 10" ID, and 14.5" bolt spacing.
------------- AC 200, CAH, AC185D bareback, AC 180D bareback, D17 III, WF. D17 Blackbar grill, NF. D15 SFW. Case 1175 CAH, Bobcat 543B,
Posted By: PDehring
Date Posted: 18 Jan 2020 at 4:52pm
I found them on a pallet and didn't have a tape measure on me so the casting number was all I could get.
They did have 6 bolt holes and are similar to those dimensions so probably fit a 190/200
Posted By: levipatch
Date Posted: 18 Jan 2020 at 5:55pm
Not a wheel weight Question exactly, but how much (gallons ) Fluid should be in a 16.9x 28 tire. One of mine is about one third ,the other none I think. looking at the sweat mark.... D 17 ser 4 diesel. Im guessing the one third is 50 gals or less . Don't really know what they should have on average...Thanks Billy
------------- Billy..Big cam 300, bcam 400,,941 CAT.,,Deere excavator..900 row crop.. 66 D 17 diesel IV... 985 Pratt and Whitney..4360 Pratt and Whitney... gitten tired !
Posted By: Stan R
Date Posted: 18 Jan 2020 at 6:05pm
https://www.tractorbynet.com/forums/files/yanmar/200467d1297731117-tractor-tire-water-ballast-weight-tireballastchart-gif" rel="nofollow - tire ballast
Posted By: DougG
Date Posted: 18 Jan 2020 at 6:11pm
Do they look heavy ? As in 275 lb heavy for one weight ?
Posted By: PDehring
Date Posted: 18 Jan 2020 at 6:14pm
I don't think they were that heavy, I was able to move one around. Probably 150lbs, but I dont know for sure.
Thanks Got it now
Posted By: DougG
Date Posted: 18 Jan 2020 at 6:17pm
If they are the 6000 series , lockable ones , they are worth some $$$
