Print Page | Close Window
1952 WD Throttle Linkage
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=166955
Printed Date: 10 Jan 2025 at 7:58pm
Topic: 1952 WD Throttle Linkage
Posted By: meashley
Subject: 1952 WD Throttle Linkage
Date Posted: 27 Dec 2019 at 7:44am
Does anyone have a picture of how the throttle linkage is connected? I got the tractor without the carburetor installed and the linkage from the governor does not seem to fit on the carb.
Posted By: Sugarmaker
Date Posted: 27 Dec 2019 at 4:15pm
I have this one:
Posted By: SteveM C/IL
Date Posted: 27 Dec 2019 at 9:25pm
my WD link is straight. Think Chris's shaft to gov is twisted.
Date Posted: 28 Dec 2019 at 8:28am
Steve,
 Mine was straight too, but this is the amount it needed to be shortened to have the governor to carb distance correct, as mentioned in several posts on here. I guess I would call this a part of the linkage tuning for the entire system. Some folks and I believe the books talk about bending the governor arm. I choose to bend the rod, just seemed easier to adjust that way.
I have done this to all three of my WD series tractors. What I cant figure out is why they ar all too long from the factory? Maybe Dr. Allis can explain this?
Posted By: meashley
Date Posted: 01 Jan 2020 at 9:36am
Mine is also straight. The linkage connected to the governor looks like it will connect to the carb but, it appears that the governor will pull the throttle the wrong direction.
Posted By: meashley
Date Posted: 01 Jan 2020 at 9:39am
I have attached a picture of mine. Does anyone have a picture of how the linkages are connected. The one going to the governor and the choke?
Date Posted: 01 Jan 2020 at 1:50pm
Assuming you have the correct carb. The rod from the gov should enter the pivot on the back side of the carb. Some times its easier if you have a tractor close by that you can look at. Thats why I have 3 or 4 of these WD series tractors around to view! Lots of things can happen when tractors are taken apart.
