Print Page | Close Window
Solid Axle in a 716??
Category: Allis Chalmers
Forum Name: Garden Tractors
Forum Description: A great place to discuss the Simplicity and Allis Chalmers Garden Models
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=159621
Printed Date: 19 Mar 2026 at 4:21pm
Topic: Solid Axle in a 716??
Posted By: KevinON
Subject: Solid Axle in a 716??
Date Posted: 03 Apr 2019 at 11:54am
Hi all.  What exactly is involved in putting a solid axle in the 716 six speed transaxle?  I want to do one for stock garden tractor pulling.  Thanks!!
Posted By: HudCo
Date Posted: 04 Apr 2019 at 9:14pm
cub kadet if your rules allow it
Posted By: KevinON
Date Posted: 05 Apr 2019 at 7:32am
They will allow it, but I refuse to use a cub rear end, as 95% of what is pulling are cubs....lol!  I have had good luck with the Simplicity rear end, I have just heard of the solid axle and would like a bit more peace of mind.
Posted By: Dakota Dave
Date Posted: 05 Apr 2019 at 9:58am
just take the diff end apart and flip some of the planet gears and it locks the diff. it only takes a few minutes and is easy to reverse.
Posted By: KevinON
Date Posted: 06 Apr 2019 at 7:26am
Thanks, Dakota Dave.  I appreciate the help.  I had heard guys twist the axle tubes and that is why they put a solid axle in them.  Cheers.
Posted By: HudCo
Date Posted: 07 Apr 2019 at 11:32am
use the the four speed transaxle out of a jd 112 axle houseing is all cast irondrive pully is on the right side very stong rear end
Posted By: Steve in NJ
Date Posted: 07 Apr 2019 at 7:29pm
How about the rearend out of a Panzer? Supposed to be a tiny 8 3/4 Chrysler rear!
Date Posted: 19 Apr 2019 at 12:10pm
I have one that twisted the axle tube when i took it apart it had been cracked 2/3 of the way around and the key ways were realy worn. You can get a new tube from sandy lake. You just split the case and you can get it out.
Posted By: iowaacman
Date Posted: 27 Apr 2019 at 2:37pm
I have exactly what you are looking for. 3 speed transmission with solid rear axle. Heavy duty hubs with adjustable hitch and weight bracket. Cost $500 to build axle and hubs. Would take $250 for the whole rear end (wheels not included).
Posted By: HudCo
Date Posted: 27 Apr 2019 at 9:21pm
what model is that from?
Date Posted: 28 Apr 2019 at 9:52am
716 six speed. Quite pulling and put a hydro back in it.
Posted By: KevinON
Date Posted: 28 Apr 2019 at 12:43pm
Im interested in it. I will pm you a bit later.   Thanks!
