1982 AC 8030 Oil Pressure Light
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=158205
Printed Date: 28 Apr 2024 at 6:19am Software Version: Web Wiz Forums 11.10 - http://www.webwizforums.com
Topic: 1982 AC 8030 Oil Pressure Light
Posted By: sjefferys
Subject: 1982 AC 8030 Oil Pressure Light
Date Posted: 15 Feb 2019 at 8:06pm
My 1982 AC 8030 seems to be running just fine, however, the Oil Pressure light is coming on when I start it and even while running. Engine oil looks good and tractor operating as normal. Wondering if it is possibly a bad oil pressure switch. Does anyone know where this is on the tractor? Also, anyone have a suggestion on a good place to purchase a replacement switch? Tried finding one online and cannot seem to find one for an 8030.
Thank you for any help you can provide.
Posted By: victoryallis
Date Posted: 15 Feb 2019 at 8:30pm
Check the wires. Mine had a nick in the wire.
------------- 8030 and 8050MFWD, 7580, 3 6080's, 160, 7060, 175, heirloom D17, Deere 8760
Posted By: MACK
Date Posted: 15 Feb 2019 at 9:31pm
I would screw sender out and a gauge in to be sure. Yes, them senders are junk. MACK
Posted By: lentsch
Date Posted: 16 Feb 2019 at 10:15am
According to Agco parts catalog sensor is on the right side of block-one wire to it. Part number 70268784 (analog) or 70264849 (digital). I sometimes use a short nipple with a T and use both a sensor and a manual gauge. Call me paranoid but I don't trust these sensors with something as important as oil pressure.
------------- WD,D15,190XT,7000,8010x2,7060,8070
Posted By: captaindana
Date Posted: 16 Feb 2019 at 7:00pm
Lent sch's got it right, I concur!!👍
------------- Blue Skies and Tail Winds Dana
Posted By: bradley6874
Date Posted: 16 Feb 2019 at 7:32pm
I agree as well tee and a Manuel gauge that's also called a to late light uasually when it comes on its to late damage is all ready done I also but a seat belt buzzer in line with the light to get your attention
------------- You can wash the dirt off the body but you can’t wash the farmer out of the heart and soul
Posted By: SteveM C/IL
Date Posted: 16 Feb 2019 at 8:20pm
Added a T and a gauge. Figured the light might catch my attention.
Posted By: Ross D.
Date Posted: 16 Feb 2019 at 8:43pm
I found this picture: Ross.
Posted By: AC720Man
Date Posted: 17 Feb 2019 at 9:06pm
Ross, that’s my XT I posted last year after I installed the gauge. I also had a sending unit go bad while baling hay. The red light lit up and I feared the worst. Hauled her home on my goose neck. Ordered a new sending unit and thankfully that was my problem. Also ordered the gauge and components at the same time. It has been a great addition, gauge is easy to see and gives me the peace of mind that I was looking for. Still have the idiot light also.
------------- 1968 B-208, 1976 720 (2 of them)Danco brush hog, single bottom plow,52" snow thrower, belly mower,rear tine tiller, rear blade, front blade, 57"sickle bar,1983 917 hydro, 1968 7hp sno-bee, 1968 190XTD
Posted By: lentsch
Date Posted: 17 Feb 2019 at 9:23pm
Would like to add-be sure to use a copper line to gauge(as pictured.)Some of the auto parts store gauges come with a plastic line which can easily melt or break.
Date Posted: 19 Feb 2019 at 6:27pm
Thank you to everyone for your help and suggestions. Found the switch and noticed it has a little oil leaking from it. Not sure if that indicates anything serious or not. It appears that it simply screws into the block. Not sure how to tell if it is bad or not. I unplugged and the light of course went off. Plugged back in and light back on but everything seems to be running fine. Trying to find where to purchase a new one to double check the switch.
Date Posted: 19 Feb 2019 at 8:15pm
I don’t remember it as being expensive.
Posted By: AC720Man
Date Posted: 19 Feb 2019 at 8:21pm
Less than $20, I got mine through Sandy Lake Imp. In PA. They have quick shipping.
Posted By: Acdiesel
Date Posted: 20 Feb 2019 at 10:56am
NAPA #OP6613 NORMALLY CLOSED 1/8"X 27 NPT
------------- D19 diesel,D17 diesel SER.3 D14 NF,D14 WF, D15 SER.II wf D15 SER.2 DIESEL,D15 ser.II nf D12 SER.I, D10 Ser.II 2-720'S
Gmc,caterpillar I'm a pharmacist (farm assist) with a PHD (post hole digger)
