Print Page | Close Window
oil milky on rebuilt c
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=15686
Printed Date: 04 Feb 2025 at 4:41pm
Topic: oil milky on rebuilt c
Posted By: jb from md
Subject: oil milky on rebuilt c
Date Posted: 25 Jul 2010 at 4:04pm
i bought a c that was tore down. it came with a different block,he said the old one was cracked.i bought a rebuild kit and had the machine shop install the sleeves. i put it all together an it started right up i ran it for about 10 min then shut it off ... went back checked the oil and it was all milky. the machinist said the block where the orings seat were pitted. but he put them in anyway.i think it may have rolled a oring when they were put in.. where can i get a set of new orings..or a running engine for my c?? thanks in advance JB
Posted By: CTuckerNWIL
Date Posted: 25 Jul 2010 at 4:12pm
First thing, check the core(freeze) plugs in the top of the head. If they weren't changed I would do that. If you still have a problem drop the pan and pressurize the water system to about 10 psi and look for leaks around the bottom of the sleeves. O-rings can be replaced but there are different sizes depending on the sleeves that were put in.
Posted By: Bill Long
Date Posted: 25 Jul 2010 at 4:18pm
Good advice Charlie.  We always looked for freeze plugs even in the 40's.
Good Luck!
Bill Long
