Print Page | Close Window
Woods L-59 belt size?
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=152206
Printed Date: 08 Apr 2025 at 5:47am
Topic: Woods L-59 belt size?
Posted By: Steve Jelf, So KS
Subject: Woods L-59 belt size?
Date Posted: 18 Jul 2018 at 2:03pm
I hope somebody can tell me the correct belt size for this L-59 mower on a Model B. I laid out and measured the old broken belt and bought a 220" replacement. Too short. So I sent it back and bought a new 228" belt. Still too short. Not even close to fitting. If someone can tell the correct length, maybe I can avoid a couple of months of buying and returning belts that don't fit.
Posted By: HoughMade
Date Posted: 18 Jul 2018 at 2:43pm
I have one, but have not had to change the belt.  I always though it was 226" around the outside.  What hole are push the arms in?  Could the deck be moved back?
1951 B
Posted By: den/southern illinoi
Date Posted: 18 Jul 2018 at 2:48pm
I agree with HoughMade. I just bought one 2 months ago and it is 226 inch belt.
As he said...it depends on how you have it set up...what holes you have it on as far as the front and back setting is.   Den
Own 4 wheel 20, 2-5015, 5020 and associated equipment and 2 electric forklifts.
Posted By: Alvin M
Date Posted: 18 Jul 2018 at 2:49pm
woods # 3652 on ac B  5/8x228 for l-59  check if if the adjustment is front the whole way
Posted By: Butch(OH)
Date Posted: 18 Jul 2018 at 2:53pm
 B228 is the right belt. If it is too short you need to unpin the frame where it pivots at the rear and move the deck back until it is long enough and stick the pins back in.
Posted By: Dick L
Date Posted: 18 Jul 2018 at 3:00pm
The picture looks as though you have yours set forward farther than I set mine.
Date Posted: 18 Jul 2018 at 3:09pm
OK, I'll see if I can move the deck back. Apparently the old belt was oversized. Thanks, all.
Date Posted: 18 Jul 2018 at 3:24pm
Looks like mine is further back, yet.
1951 B
Posted By: Hubert (Ga)engine7
Date Posted: 18 Jul 2018 at 8:39pm
Steve, good to see you posting on here again. Still tinkering with the Model A's?
Posted By: TedBuiskerN.IL.
Date Posted: 18 Jul 2018 at 8:48pm
Get the belt from Woods, it will outlast three of the others, and be sure to get the twists in the right places or they don't last very long.
Posted By: Dick L
Date Posted: 19 Jul 2018 at 5:43am
I have not found that to be true Ted. I just replaced a NAPA belt after 6 full seasons and the most I ever got from a Woods belt was two.
