Print Page | Close Window
Pulling Question
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=15075
Printed Date: 03 Feb 2025 at 7:00pm
Topic: Pulling Question
Posted By: Jeff-in-Kunkletown
Subject: Pulling Question
Date Posted: 12 Jul 2010 at 10:15am
I have a WD-45 that I started pulling with in the antique/classic 4500 class around home. The rear tires are loaded and the tractor weighs 4480 with me on. Engine is newly rebuilt to factory specs. What do you recommend for air pressure in the rear tires? Also is it better to drop the calcium and use wheel weights instead? The rims are starting to rust pretty good and I'll probably change them over the winter. Thanks.
Posted By: Shane H. (Mi)
Date Posted: 12 Jul 2010 at 12:03pm
I run about 8# in unloaded tires (13.6x28) on my WC. Dad convinced me to run without the chloride. "Run as light as you can, then weight-up..." I guess our parents sound wiser...the older we get.
hth
-Shane'r
