Print Page | Close Window
172 rotary mower problems
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=150202
Printed Date: 15 Dec 2025 at 4:58am
Topic: 172 rotary mower problems
Posted By: Pat the Plumber CIL
Subject: 172 rotary mower problems
Date Posted: 06 May 2018 at 7:58pm
Turn pto on and blade would not spin . Looked under neath and shaft coming down was spinning when pto was on . Tapered splined shaft is not splined any more. I am going to local AGCO dealer tomorrow to pick up filters and oil for my Kubota side X side so will see if shaft is available. Part # 537830
If part is not available and cannot find a salvage one, what are my options? Can spline shaft be built up and machined back to usable? Anybody got one laying around ?
Date Posted: 06 May 2018 at 8:03pm
Hey I actually posted a picture from my phone. Woo hoo!!!, hot damn !!! . Little big but I will take it . Took me all day to get that shaft out . Wonder what a new heavy-duty woods bush hog would cost?
Posted By: DiyDave
Date Posted: 06 May 2018 at 8:21pm
It could be built up and re-machined, But would be major $.  If agco can get it, it will also likely be major $.  Best thing would be a whole gear box, offn a rusted thru donor mower. IIRR, 160 and 172 use the same box...
Posted By: Tracy Martin TN
Date Posted: 06 May 2018 at 8:24pm
If NLA, I would have a machine shop machine one from 4150 steel. No taper, straight shouldered, machine two keyways opposite each other. Take the blade holder hub, cut the old tapered hub off and weld on a hub made to match double keyed shaft. Welded hub will need split lines and have a tightening ears on one or both sides. Older Woods mowers used this. Works good too. HTH Tracy
