Print Page | Close Window
670T Crank Pulley
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=149858
Printed Date: 29 Nov 2024 at 7:38pm
Topic: 670T Crank Pulley
Posted By: smitty78
Subject: 670T Crank Pulley
Date Posted: 25 Apr 2018 at 8:16pm
L2 Gleaner with 670T - crank pulley shivs had slipped a bit so sent it to Dale mfg, beautiful repair and priced right.  A few hours later usage noticed the inner hub had cracked.  Wondered if I over torqued the bolt and the tapered shaft made it fail ?  Does anyone know the torque spec on the crank pulley bolt ?
thanks, smitty
Posted By: MACK
Date Posted: 25 Apr 2018 at 9:29pm
220ft lbs.torque with all oil removed from both. Dry.    MACK
Posted By: smitty78
Date Posted: 25 Apr 2018 at 9:43pm
So, the crank & hub tapered surfaces should be un lubricated during torque ?
Posted By: SteveM C/IL
Date Posted: 25 Apr 2018 at 11:30pm
That's what Mack said.
Posted By: smitty78
Date Posted: 28 Apr 2018 at 6:10am
I was able to remove my 4 groove crank pulley without removing the radiator which was lucky but now having a hard time finding a replacement.  New over $1,500 (nearing value of entire combine, LOL), used $660, ouch.
New 3 groove around $500, but can you drive the alternator with just 1 belt and will it line up ?
Why don't those aftermarket monkeys offer a 4 groove ?  I'm not sure I've ever even seen a 3 groove setup, most are 4.
Anybody have a 4 groove for sale ?
Notice the crack in the inner hub aligns with keyway and threaded hole ... perhaps a weak path
Thanks,
smitty
uploads/13642/crank_pulley_2JPG.jpg" rel="nofollow - uploads/13642/crank_pulley_2JPG.jpg
uploads/13642/Crank_Pulley_1JPG.jpg" rel="nofollow - uploads/13642/Crank_Pulley_1JPG.jpg
Posted By: MACK
Date Posted: 28 Apr 2018 at 10:33pm
I may have one on a L2 motor. Will check.    MACK
Posted By: smitty78
Date Posted: 29 Apr 2018 at 9:38pm
duh ... answered my own question ... the 3 groove pulley is a tractor application with the single belt driving the AC compressor, likely was more field demand than the 4 groove in which 2 belts drive the hydraulic pump. I imagine 1 belt would drive the hydraulic pump but the shivs wouldn't match (AC belt is thinner than hyd belts) so I'll keep looking for a 4 groove. Almost bought an L2 for parts saturday at a sale, was hung on 1K for awhile but ended up at 3K per a good auctioneer.
