Print Page | Close Window
226 in a 175
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=149652
Printed Date: 18 Sep 2025 at 9:23am
Topic: 226 in a 175
Posted By: Gary Burnett
Subject: 226 in a 175
Date Posted: 19 Apr 2018 at 7:49am
What does it take to put a 226 gas (D17 style) into a 175 that now has a diesel
motor?
Posted By: tbran
Date Posted: 19 Apr 2018 at 8:12am
depends on the version of 175 - late style - front pto drive (not available new) and shaft  proper clutch pressure plate - can use either on the late 175's.  If is a early you have to have the splined pressure plate as well. The pump must match the tractor steering well.  Throttle linkage mods.  Choke cable.  Rear engine adapt plate.  Redrill mtg holes in frame -  or you can  email me mailto:bgtbran@hotmail.com" rel="nofollow - bgtbran@hotmail.com    as I have an excellent 248 diesel  in a 175, with a junk tranny rear end that we are salvaging.
Posted By: DrAllis
Date Posted: 19 Apr 2018 at 8:55am
Also, the gasser engine requires a longer clutch shaft in the torque tube, which unless the flywheel can get moved back 1.25+ inches, kind of nixes the whole deal, right ???
Posted By: Tracy Martin TN
Date Posted: 19 Apr 2018 at 8:59am
Buy the engine from tbran, you will be money ahead! Tracy
Posted By: DSeries4
Date Posted: 19 Apr 2018 at 4:34pm
Don't know why anyone would want to put a gas engine in.  The 248 Perkins is much more efficient and reliable.
Posted By: orange-is-power
Date Posted: 19 Apr 2018 at 6:23pm
Don't get much more reliable than a 226. There's a reason A-C used them in tractors for what, 25 years?
Posted By: DSeries4
Date Posted: 19 Apr 2018 at 6:46pm
I am not knocking the 226 one bit.  I am just saying that the 248 Perkins is extremely reliable and a properly rebuilt one would be better than trying to fit a gasser in the chassis.
Date Posted: 19 Apr 2018 at 7:49pm
Don't think the diesel in the one i'm looking at will be too good has a busted block,plus I have a couple 226 motors but seems like it wouldn't be worth the effort to change it over.
Posted By: rieg
Date Posted: 19 Apr 2018 at 8:03pm
tbran I just sent you an email from my yahoo account. rieg
rieg
Posted By: Peterson
Date Posted: 20 Apr 2018 at 6:42am
Don't the 170-175s gas and diesels use the same clutch shaft? Only the d17s had the different length ones.
7095-685I at 255hp, 8070-225HP,8050-210Hp,8030 with 155HP,220 with 670T engine with A-pump, 7580, 185 with 140HP, 2-6080's,6070, S4 D17,wd45,CA,st34 agco, S1 D17 with 3500MK2
Posted By: steve fischer
Date Posted: 20 Apr 2018 at 7:32am
I am putting a 433 turbo off of f2 combine  in one right know ,248 was run out of oil bad block , I also am making front pump drive kits for gas and diesel
Posted By: DrAllis
Date Posted: 20 Apr 2018 at 9:08am
I had to look on AGCOPARTS.com and sure enough, the Perkins engine uses the same long clutch shaft as a gasser. It's when you try and adapt an A-C 4 cylinder in that chassis the clutch shaft length causes a problem.
Posted By: Kevin in WA
Date Posted: 20 Apr 2018 at 8:49pm
I think only the D17s had different length clutch shafts between gas and diesel
