Print Page | Close Window
AC 5050 brakes
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=149485
Printed Date: 10 Sep 2025 at 10:01am
Topic: AC 5050 brakes
Posted By: Donkey376
Subject: AC 5050 brakes
Date Posted: 15 Apr 2018 at 6:19am
Has anyone ever attempted to change the brakes on a 5050? I have the manual finally and it doesn't look too bad....but I was wondering how bad those pivot pins come out? I don have access to torches anymore....
Posted By: bozrae
Date Posted: 16 Apr 2018 at 6:37am
It's likely you'll need a torch unless your pins aren't rusted to bad, then you may be able to just pull them out.I did both sides of the brakes on my 5050 a few months ago, but I did end up using a torch to cut out the old bands and then pounded out the pins with a punch.
D15D, D17G, 170G, 175D, and two 5050FWA
Date Posted: 16 Apr 2018 at 6:42am
Didn't happen to take any pics did you? I've never done anything like this before....I'm used to my Farmall Cub lol.
Posted By: bozrae
Date Posted: 16 Apr 2018 at 8:35am
The pictures I have may not be real useful, but here they are. The side shown in the pictures was the most difficult to remove because they were filled with muddy, rusty gunk. The brake lever shaft needs to be removed first and I had to heat the tapered bolt holding it onto the lever also.  Putting the brake bands back in can be tricky, but with patience it is possible.
Posted By: bozrae
Date Posted: 16 Apr 2018 at 8:38am
A good source of parts I found is: Ricks Ag Parts LLC
http://stores.ricksagparts.com/allis-deutz-agco/" rel="nofollow - http://stores.ricksagparts.com/allis-deutz-agco/
Date Posted: 16 Apr 2018 at 12:54pm
Those are helpful! The only tractor experience I have is with my Cub I use to mow our land...
What'd you use to yank the finals? Engine hoist?
Posted By: bozrae
Date Posted: 17 Apr 2018 at 6:14am
The 5050 is a little more complex than a Cub, but once its back in working order you'll probably find it a good usable tractor.
I used an engine type puller or 'cherry picker' to remove the axle housing. I did find one picture with the chains attached to the housing.
Date Posted: 18 Apr 2018 at 10:32am
Its def a different animal than the cub! Thank you very much for your help...I'll tackle it soon.
Posted By: Dan Hauter
Date Posted: 19 Apr 2018 at 8:58pm
I have a 5050 and so does a friend.  Good, tough little tractors.  They're actually Fiats.
Date Posted: 24 Apr 2018 at 2:07pm
I love mine but just wish I had more time to tackle it...the wiring is completely butchered. Someone put a newer 1 wire alternator on it and nothing really works (ignition is bypassed too)...Sometime Ill get around to rewiring it then go from there.
Posted By: bozrae
Date Posted: 24 Apr 2018 at 3:31pm
They do seem like rugged tractors. I've been into the wiring on both of my 5050's and was able to get everything working again, but the manual doesn't have the greatest wiring diagram. At some point they changed to a different style alternator with a built in voltage regulator, but the diagram is not updated.
Date Posted: 24 Apr 2018 at 3:34pm
There's no external regulator or fuse box on mine...just a complete disaster and I really have no idea where to start lol
