Print Page | Close Window
Oil pressure Allis C
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=149062
Printed Date: 06 Oct 2025 at 1:23am
Topic: Oil pressure Allis C
Posted By: John426
Subject: Oil pressure Allis C
Date Posted: 02 Apr 2018 at 3:00am
Hi
i have a problem of oil pressure with my Allis Chalmers C.
When I'm on a steep climb (uphill) or a banked, the oil pressure becomes very low, close to zero.
Then returning to flat, the pressure will gradually go back to normal position.
The strainer was cleaned about 100 hours ago and the oil filter changed 100 hours ago too.
Where could this problem come from?
Posted By: DougS
Date Posted: 02 Apr 2018 at 4:34am
The pickup tube is placed correctly, I presume?
Posted By: AaronSEIA
Date Posted: 02 Apr 2018 at 7:00am
Is the oil level where it should be?
AaronSEIA
Posted By: Larry in NC
Date Posted: 02 Apr 2018 at 8:12am
That is strange, do you think the gauge could be bad?  I assume that the tractor does maintain good oil pressure when idling?
Posted By: Gerald J.
Date Posted: 02 Apr 2018 at 9:11am
Shop manual may have a hint. My guess would be low oil level in the crankcase.
http://geraldj.networkiowa.com/Trees/Allis-Chalmers-G-B-C-CA-Service.pdf" rel="nofollow - http://geraldj.networkiowa.com/Trees/Allis-Chalmers-G-B-C-CA-Service.pdf
Gerald J.
Posted By: Leon n/c AR.
Date Posted: 02 Apr 2018 at 3:32pm
If the oil shows to top of full mark I would add half quart see if it still goes down add the other half quart and try again.  Like Gerald I think the oil level is low or the screen is too high. Leon
Posted By: John426
Date Posted: 03 Apr 2018 at 12:34pm
The oil level is O.K . Today i remove the cranckase, and i see that the pcik up tube was not in the coorect position . Too high.
Now it is ok. Thanks a lot for your help
Date Posted: 03 Apr 2018 at 1:44pm
Glad to hear you found the problem. Super nice looking tractor and mower. Leon
Posted By: Ted J
Date Posted: 03 Apr 2018 at 9:24pm
Nice looking!!!  Glad you figured it out.  They ARE simple.
Looks like you have some kind of horn hooked up and what's with those headlights?  They look oversize and Yellow bulbs?
