500 Loader Cylinder question
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=143953
Printed Date: 12 Oct 2025 at 7:13pm Software Version: Web Wiz Forums 11.10 - http://www.webwizforums.com
Topic: 500 Loader Cylinder question
Posted By: Fuzzy
Subject: 500 Loader Cylinder question
Date Posted: 30 Oct 2017 at 8:36am
I need to buy fittings for the cylinders on my loader, but don't have access to them right now to know the correct size/type fittings to get.
I think I need pipe threads to screw into the cylinder and female o-ring to screw the hydraulic hose onto? I think it is standard 3/8 hose from tractor supply? Does this sound right?
What sizes on each end?
Posted By: Joe(TX)
Date Posted: 30 Oct 2017 at 10:22am
I'm pretty sure the cylinder fittings are NPT. Our Tractor Supply only has hoses with NPT ends. The fitting shown is a NPT swivel.
------------- 1970 190XT, 1973 200, 1962 D-19 Diesel, 1979 7010, 1957 WD45, 1950 WD, 1961 D17, Speed Patrol, D14, All crop 66 big bin, 180 diesel, 1970 170 diesel, FP80 forklift. Gleaner A
Posted By: Fuzzy
Date Posted: 30 Oct 2017 at 2:36pm
So NPT pipe on both ends, is what I'm hearing?
Posted By: Joe(TX)
Date Posted: 30 Oct 2017 at 6:37pm
I looked at my 400 and all the hoses had 3/8 NPT male ends. Some were swivel ends. Fixed ends can be used with the swivel adapter. I am pretty sure the 500 uses the same type hoses, at least according to the parts book.
Posted By: orangereborn
Date Posted: 31 Oct 2017 at 12:36am
Yes. all 3/8 NPT on cyl's of both the 500 & 400 that I have. I know the 500 has 1/2 steel lines on the boom to the front tilt jct. I think the 400 also but have to look for sure. I moved the front jct's on the cross over tube for the bucket cyl's to the top of the tube vs the back. On a 180 so the starter wt didn't interfere. I do not care for the hose arrangement and as the hoses need replacing, I am putting steel lines from the jct back to the base of cyl's and basically short straight length of hose for the little flex it needs....Dale
Posted By: Fuzzy
Date Posted: 31 Oct 2017 at 10:59am
