Woods 59 Help Requested
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=143892
Printed Date: 28 Sep 2024 at 11:22pm Software Version: Web Wiz Forums 11.10 - http://www.webwizforums.com
Topic: Woods 59 Help Requested
Posted By: KenBWisc
Subject: Woods 59 Help Requested
Date Posted: 27 Oct 2017 at 7:44pm
I ordered a front roller for my mower but am not clear on how to mount it. The diagram in the book seems to hang it in mid air. Wisconsin air is too thin for this to work. Would anyone have a photo of how this thing mounts?
------------- '34 WC #629, '49 G, '49 B, '49 WD, '62 D-19, '38 All Crop 60 and still hunting!
Posted By: rustyorange45
Date Posted: 27 Oct 2017 at 8:39pm
I just found a roller for my mower and was going to put it on this evening, but it got dark. If you look at the front top of your mower deck you will see two sets of square holes about 13" apart. I am using 3/8"x1 1/2" carriage bolts to mount it to the deck. The parts diagram I saw has the carriage bolts going through the roller brackets, then up through the deck. I am going to put mine through from the top of the deck, because when I take it off, I can just cut the nuts off from the bottom without damaging the paint on the deck. Plus I think it looks cleaner. Hope this helps!
------------- 1953 WD45 WF/Model 90 Loader, Oxnard Rear Blade, 80R Mower, Model 209 Disc, WD Rear Mounted Scoop, Model 184 & 160 Rotary Mowers, 1952 CA NF/L306CA mower, 1953 CA WF/Model 8 Loader.
Posted By: Dick L
Date Posted: 28 Oct 2017 at 5:52am
Any pictures of what your working with?
Posted By: mdm1
Date Posted: 28 Oct 2017 at 6:06am
I found a page that says there should be mounting instructions included in the roller bundle. It said some decks are not predrilled. http://farmallcub.com/rudi_cub/www.cleancomputes.com/Cub/OEM%20Implement%20and%20Attachment%20Manuals/Woods%20Mower%20Manuals/59-LB%20Rotary%20Mower/Page-04.jpg" rel="nofollow - http://farmallcub.com/rudi_cub/www.cleancomputes.com/Cub/OEM%20Implement%20and%20Attachment%20Manuals/Woods%20Mower%20Manuals/59-LB%20Rotary%20Mower/Page-04.jpg Do you use the roller with the wheels. Just curious.
------------- Everything is impossible until someone does it! WD45-trip loader 1947 c w/woods belly mower, 1939 B, #3 sickle mower 1944 B, 2 1948 G's. Misc other equipment that my wife calls JUNK!
Posted By: Ted J
Date Posted: 28 Oct 2017 at 6:29am
Ken, sorry but I'm not up at the farm or I'd take a picture for you. Mine is an L306, but I'd bet they both mount up the same. Do you have the angle iron brackets that come with the roller? You've gotta have them. If you get stuck, send me a PM or call me if you still have my cell phone #. Have a good one buddy!
------------- "Allis-Express" 19?? WC / 1941 C / 1952 CA / 1956 WD45 / 1957 WD45 / 1958 D-17
Posted By: KenBWisc
Date Posted: 28 Oct 2017 at 10:07am
Thanks much for the responses! No, mine does not have the per-drilled holes. I'm assuming the roller brackets mount to the horizontal top of the mower deck versus the vertical. Without an angle iron bolted on the front then the brackets have to go inside the mower deck? This seems anti logical to me.
Posted By: KenBWisc
Date Posted: 28 Oct 2017 at 10:11am
Ted, The number I have doessn't seems to work. Please call me!
